Sponsors    Home    Forums  Hop To Forum Categories  Ford    Ford Powerstrokes
Page 1 2 3
Closed Topic Closed
I too have been running 50-100 percent BD in my 97 Powerstroke for a few months now with no apparent ill effects. I do not wash it. I brew it in my solar processor, filter it, settle it for a day or two and put it in the tank. The O-rings are viton, which is a synthetic rubber, which is not affected by the methanol. For more information than you can stand on Powerstrokes, go to www.thedieselstop.com. They are great there and very knowledgeable.
Cool
Location: Denver | Registered: 23 November 2002Edit or Delete MessageReport This Post
I've been trying to get some input about the older F-250s with the 6.9 and 7.3 L diesels. These were also made by International(Navistar). I've been concerned that these may have natural rubber parts in the fuel system since they are older. Rememeber, it is the natural rubber that organic solvents can soften, not more recent synthetic rubber compounds.
Location: Gainesville, Florida,USA | Registered: 23 April 2003Edit or Delete MessageReport This Post
k-t
hi, im looking at getting a ford f250 made in 1984. acording to the seller it only has 122k miles on it, so it wouldnt be as terrible as it sounds... or would it??? advice on a powerstroke engine this old???
thanks
katie salt
Location: arcata, ca 95521 | Registered: 23 May 2003Edit or Delete MessageReport This Post
Thats not a powerstroke. I`m not sure but maybe a 6.9L ? check your numbers again Wink
while no expert there should be no problems regardless of what it is
have fun Big Grin
7 years off the grid and counting
Location: Muskoka, Ont, Can | Registered: 23 March 2003Edit or Delete MessageReport This Post
Originally posted by mamagrrl:
Is anybody running a '97 F250 on pure BD?
$800 bucks to switch out some o-rings - OUCH!
Anyone?
I'v been running my '96 ps on pure b100 for about 5 months. My advice is STOP!!! CHECK ALL RUBBER FUEL LINES. My truck, as of yesterday, is dead in driveway with oozing fuel lines.
Registered: 27 May 2003Edit or Delete MessageReport This Post
I am running a50/50 blend of wvo/no2 diesel in my 95 F-350 PS. I'm thinking about using biodiesel instead of no2. I am curious about how DonutDually's 95 F-350 PS is doing on his homebrew biodiesel after a year and a half of service. Anyone else out there running wvo in a blend like this in this engine? I just started and have burned about 50 gallons of wvo with no problems in our hot summer weather.
Registered: 02 August 2004Edit or Delete MessageReport This Post
DN
FredPe
I run blend.No mods. 85% wvo &15% rug.
David Norwood
Updated 1/2009 .
Location: Upstate South Carolina , USA | Registered: 28 December 2003Edit or Delete MessageReport This Post
Go to www.thedieselstop.com There is a section for Biodeisel and other alternative fuels. Keith
I have a 2004 Ford F350 6.0 PSd that run B25 in the winter and B50 in the summer. See pics in homepage.
Location: Schwenksville, Pa. | Registered: 30 October 2004Edit or Delete MessageReport This Post
'95 Ford F-250 7.3L PowerStroke
Dual Fuel Tanks, bought it solely for BioDiesel.
I pump b100 in the rear tank, and petro in the front. If its gonna drop below 25 or so, i make sure to swith over to petro before shutting it down for the night. I've had no comparable loss of power. My truck has 200,000 miles on it, and i've ran biodiesel on it for only about 3,000 miles now, but expect to get a good 100k out of it pretty easily.
Location: colorado | Registered: 18 December 2004Edit or Delete MessageReport This Post
Hello
Just looking to find out how the newer powerstroke is running on B100. I have a 2004 6.0 that i would like to run on bio but have some concerns.
Originally posted by Shaun:
My company has a 2001 Ford F-450 powerstroke being delivered next month. We're going to run it on 100% biodiesel like we do our two other work trucks, both international 7.3 liter (about 40,000 miles between them on about B99). I'll keep y'all posted on the results.
Shaun
Registered: 10 March 2005Edit or Delete MessageReport This Post
I have been running my 99 on B100 for about three months. For a couple months before that I used a blend, depending on the temps in New York. The fuel is home brewed and is washed.
So for no problems.
Location: New York | Registered: 03 December 2004Edit or Delete MessageReport This Post
Administrator
I guess I'm overdo for an update on our 2001 F-450 7.3. We're over 63,000 miles, all on B100 from Pacific Biodiesel, and runs great. The only issues we've had with the truck were at 20,000 miles the computer needed a software upgrade of some sort and we had to replace the transmission earlier this year.
We just added our 2004 F-450 6.0, so I will update on that sometime in the near future.
24 B100 vehicles
19 Bio-Beetle Rentals
http://www.bio-beetle.com
4 Recycling trucks
http://www.mauirecycles.com
1 1982 Mercedes 300TD
Location: Maui, Hawaii | Registered: 09 June 2003Edit or Delete MessageReport This Post
Originally posted by DonutDually:
I've now been running on B100 in my 95 Ford F350 7.3L powerstroke dually (@135K mi.) for about 3 weeks without any problems. At first I thought the hard starting in the mornings might be due to BD, Frown but it turned out just to be the glow plug relay which is known to be a problem. There is a GREAT website on PS Tips & Tricks at http://pages.prodigy.net/stevebaz/_import/pages.prodigy.net/stevebaz/index3.html
I swapped out the GPR and it starts fine even at 45F. Big Grin Very comparable performance with no changes in injector timing yet. Thinking about a MicroTuner to change the timing a bit.
I make BD out of FVO in 55 gallon batches WITHOUT any washing (per Tickell's recommendation). I refuse to ADD water my fuel when it's so nasty to diesel engines! The pH is about 9.0 after 24 hours of "bubble polishing" to eliminate the methanol and the BD gets crystal clear. I do a final filter to 1 micron along with a dewatering filter inline. Check it out at http://home.attbi.com/~wiedemann/private/biodiesel.htm
Rudi
Location: Washington | Registered: 17 May 2005Edit or Delete MessageReport This Post
[QUOTE]Originally posted by DonutDually:
Have you had any problem since you posted this? I was? am? about to start using biodiesel in my '95 powerstroke, but have been concerned with the various mention of hoses and o rings failing. Are you still using B100, or have you switched to a blend?
I have a 97 Ford Diesel Pick-Up with dual tanks. I understand you must have two tanks. One for diesel and the other for veggi oil. Can I use my second tank for vegetable oil and if so how do I heat the oil in a factory tank?
Registered: 08 June 2005Edit or Delete MessageReport This Post
I am about to start running B100 in my 99 PSD, and have already planned to install a 203 thermostat instead of the lower stock unit. Since I'm runnin Evans coolant (100% with no water), I do not have near the worry about heat and other matters, such as cavitation. The increase in heat should help the viscosity of the Bio.....
Location: Gainesville/Cumming, GA | Registered: 19 July 2005Edit or Delete MessageReport This Post
AGTV, you're talking about using oil for fuel, different than biodiesel. Do a search at the SVO as fuel section of the forums, lots of information for running your truck on oil.
Scott
2000 Ford Supercab 4x4 PSD,piped, PPIII, 6spd, $10 AIC, 100 gallon aux tank, Homemade WVO conversion
Location: Burlington, WI USA | Registered: 26 February 2003Edit or Delete MessageReport This Post
I believe the powerstrokes have been compatible with 5% biodiesel for several years and in order to do so the fuel line parts have to be Viton or similar in order to resist the softening found with biodiesel.
Registered: 18 February 2005Edit or Delete MessageReport This Post
Rey
Hey all... New here and reading up on the Powerstrokes using BD, when it dawned on me that my wife is a transit driver, and the transit company she works for uses BD exclusively (they also run a bunch of PS E-350 coach bodied vans). Heres a link that should get you to their fleet info:
http://www.intercitytransit.com/page.cfm?ID=0075
Cut and paste itcuase I don't know how to make an active link.
Rey.
Oh, it came up as a link, woo hoo!
Registered: 16 December 2005Edit or Delete MessageReport This Post
That's a true statement. Ford officially "approves" of up to 5% biodiesel. It's my understanding that all fuel system rubber components have been compatible with B-100 since 1995. In today's litigous society, Ford is just being conservative.
I've run various concentrations of biodiesel (up to B-60) in my 2003 7.3 Powerstroke with no apparent ill effects.
Location: Sanford, NC | Registered: 22 December 2005Edit or Delete MessageReport This Post
Closed Topic Closed
