I find it very hard to believe one batch with some drop out would cause any problems, there are lots of folks who burn straight wvo in these engines, what is your wash process like?
glycercin prewash, 2 stage processing, 5% water prewash, 3 cycles of traditional bubble washing for 8-12 hours each, bubble drying for 24 hours, 10 micron filter on the way out.
dt '02 VW Jetta '97 F-250 7.3L Powerstroke B50 through B100 depending on weather B100 fired hot water furnace |
Completely irrelevant. Transesterferication can produce glycerin if not done correctly. There is no glycerin in vegetable oil, despite what the bd people may tell you. Yes, a small amout of glycerin can screw up the injection pump. It can pass through filters. The deposits you see are a sure sign of unburned glycerin 1-tank Elsbett VW TDI , 115,000 SVO miles. http://ctbiodzl.freeshell.org/votdi.html and a '92 F-250 with only a FPHE |
No, not really, fall out in the 3/27 is unconverted oil, unconverted oil is SVO is it not? |
Still completely irrelevant. Unless by ' lots of dropout ', ctbioman means > 25%. Even then it would take a year before it worsened to the degree reported. Since it was days, it's glycerin. 1-tank Elsbett VW TDI , 115,000 SVO miles. http://ctbiodzl.freeshell.org/votdi.html and a '92 F-250 with only a FPHE |
