I installed an inline gauge. Here is a link to parts for an install similar to your thoughts.
http://www.dieselorings.com/in...by=2&group=10&cat=13 David Norwood 2001 F350 7.3 DI purchased new by me and i believe it is the first DI Ford experimented with and talked about on this forum. The single OEM fuel tank only. Updated 1/2009 . HOH for fuel line heat from tank to 12v lift pump. GPI/CIM-TEK spin on filterhead and 10 micron filter. Two 12v 36" heaters wrapped around metal fuel lines. One before add on filter and one before OEM filter.dttk44@bellsouth.net Cool weather mixes starting spring 2009. 100% vo to 65*. 5% K1 to 55*. 10% K1 to 45*. 20% K1 to 35*. 30% K1 to 10*. |
Thanks DN, however I don't see any parts for a 2006 6.0.
Click the link and go to the contact at lower left . Send Guzzle an email on your year. I am sure he has it. But you are right, i do not see your year listed on the site.
I found an adapter hose I am going to use. Slould be ok,teflon inside braided stainless steel outside. |
I recently read on another forum that a flexable grease gun hose will work (available at TSC, Walmart, and hardware stores). Already 1/8 npt threaded on both ends. Rated for high pressure also.
