I have a 90 and a 93 7.3 and both of them use electric fuel pumps. The diesel pump for a Hummer works really well. You have not had any fun until u try to bleed a system with the mechanical pump. Both electric pumps were put on with brand new mec`hanical pumps as the mechanical pump does not want to do the job. I do live in so florida not in the north.
I have converted a 1987 F250 to run on SVO. What I did was add another tank mounted in the bed,90+ gallons. I am using a "HOTFOX" to heat the oil in the tank and oil feed tube. I'm also using a "VEGTHERM" sold by the same people that sell the "HOTFOX". Look up "ARTIC FOX INC". No I am not employed by them, just use their products with no problems.
Not to hijack an old thread but this turned up in a search. I am looking to replace the Holley red pump on my van and came across the Hummer pump but it's got female metric fittings from what I can tell. Curbill (or anyone using this pump) what fitting is it? Autozone is not real clear on their website but it looks like M16x1.5, is this correct?
1991 OBS Ford 7.3IDI E350 cargo van. Running 50-75% WVO. 90k original miles on this former bucket truck. Looking to start or join a WVO coop in the Akron Ohio area. |
rs (do you own one what is the part number of that pump, or URL so i may look it up. are you having problems with our stock lift pump or are you just looking to simplify? 80's NA VWs & NA and turbo Benzes, '91 E350 7.3 IDI NA various bicycles with trailers and gearing low enough to ride up a cliff ;-) |
I went ahead and bought it since it was only $52 at Azone and was made for the turbodiesel hummer. Look up the one for 1997. I had to use Earls adapter fittings for powersteering from Summit Racing, M16x1.5 to -6AN. I've got a 3/8 aluminum fuel line anyway so it was real easy to hook up. I was on my second Holley pump, both had the motors die after the rotors wore out. Those Holley's are noisy and I never liked them. The first one was an old one I took of my drag car when I built it up. I bought the second because I was in a hurry and figured the old one was just well, old. This Hummer pump is a dream so far. Very quiet compared to the Holley. I used an insulated strap clamp to bolt it to the frame. I ran a whole tank of 50/50 WMO/D2 blend so far with no issues even with temps getting down to the 40's around here at night.
Got the joke BTW, good thing my wife's a hummer fan 1991 OBS Ford 7.3IDI E350 cargo van. Running 50-75% WVO. 90k original miles on this former bucket truck. Looking to start or join a WVO coop in the Akron Ohio area. |
Forgot to mention:
Just search the Autozone website for a 1997 Hummer with the turbo diesel. I put in the Holley to make filter changes easier. When I first started out I was changing filters a lot and with the electric I could purge the air without cranking the engine. 1991 OBS Ford 7.3IDI E350 cargo van. Running 50-75% WVO. 90k original miles on this former bucket truck. Looking to start or join a WVO coop in the Akron Ohio area. |
What is the psi rating on the Hummer pump? Do you use a pressure regulator?
------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com |
I believe the pressure rating is around 13 but don't know for certain. I am not using a regulator. The Holley pumps are 7 PSI. The Hummer's use the same Stanadyne DB2 IP that my van uses although I believe it turns the opposite direction so I am not too concerned with pressure. Besides I suspect the pressure is a little lower trying to pull a heavier blended fuel from the tank as opposed to D2. So far so good. The pluses for me where OEM design, originally for a diesel, for an engine of similar size, available at most parts stores. Heck for the money I'm gonna keep a spare in the cab just in case.
In my experience on my IDI a 7psi pump can do 3.5-4.0 psi on 100% WVO and a 10psi gets about 5.5-6.0 psi. At least that's what my Walbro frb 5 and 13 do respectively. ------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com |
