Your fuel filters plugging up from time to time is somewhat normal when running on and off with biodiesel that is nothing to be concerned with. I would recommend installing a fuel pressure gauge after the fuel filters to monitor the fuel being supplied to the injectors. If you got 145,000 miles and only needed one fuel injector on a 6.0 you did fairly well. I would not blame the bio for that unless the fuel is poor quality. With that kind of mileage on that motor it is to be expected that injectors will start to fail. You would not have gotten that many miles had you be running straight veggie oil, however chances are good that could have happend with dino diesel as well. Hope this helps let me know if you have any further questions.
Factory Trained Ford Tech Gas and Diesel Expert
| Location: New England | Registered: 22 September 2008 |    |
Sorry to cut in Boatright, but my question centers around yours as far as running biodiesel. According to my owners manual, I can run B5 without any warranty issues on my '07 F350 6.0L, but I read elsewhere I could even run B20 without any issues, except warranty. I have 53k miles on my pickup. Which would be the wise way to go?
follow the manufacturer specs of 5% if for no other reason than to keep your warranty. I have run 50k miles of b100 on my 04 6.0 Couple of plugged filters, and I think I have a lazy injector that doesnt fire right on the first start up of the day. But at 175k miles total...I highly doubt that is from the bio
I doubt it either. Not that I know anything. But I did watch a show called Cool Fuels, about an Australian driving across USA using alternative fuels. The problems he faced when breaking where not bio related.
