I had a sudden change in performance after 1 year running on SVO. After switching tanks from SVO to diesel, the truck started running really badly, at one point I couldn't get it to start. I thought it might be air in the fuel lines so I checked the SVO conversion and fittings and put in another fuel pump. Now the trunk starts and idles fine but has no top in power. Any thoughts?
Sounds like fuel starvation to me, something in your fuel supply system got plugged, especially if this happened all of a sudden, injectors would more likely become fouled over a much longer time.
Location: fisher,illinois,usa | Registered: 03 June 2003
------ 2001 Ford Excursion 7.3l PSD 1984 Ford F-250 6.9l IDI Conceptually identical Home Brewed WVO Conversions w/ completely parallel fuel systems. Over 18,000 miles on WVO. http://www.boulderveggieoil.com
Location: Northern Colorado, USA | Registered: 26 June 2008
Originally posted by mryan: I had a sudden change in performance after 1 year running on SVO. After switching tanks from SVO to diesel, the truck started running really badly, at one point I couldn't get it to start. I thought it might be air in the fuel lines so I checked the SVO conversion and fittings and put in another fuel pump. Now the trunk starts and idles fine but has no top in power. Any thoughts?
I'm having same problems , what pump did you replace lifter pump or main fuel pump? Thanks Jerry B.
I would replace the OEM fuel filter (at the front of the engine) , which is likely shared by both the vo and diesel systems.
David Norwood
Updated 1/2009 . HOH for fuel line heat from tank to 12v lift pump. GPI/CIM-TEK spin on filterhead and 10 micron filter. Two 12v 36" heaters wrapped around metal fuel lines. One before add on filter and one before OEM filter.dttk44@bellsouth.net
Location: Upstate South Carolina , USA | Registered: 28 December 2003
