Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Ford    2008 F250
cue
I am wanting to buy a 2008 F250 with the 6.4L PSD. Does any body have any ideas as to how the new engine would like Biodiesel? Since it is a cleaner burning engine and the fact that it is using the high pressure piezo-electric injectors. Any comments would be appreciated.
Cue
Location: Western Oklahoma | Registered: 19 November 2006Reply With QuoteEdit or Delete MessageReport This Post
As far as I know the 6.4L's are only going to be happy with the 15 ppm pump diesel. All we can do is keep and ear down for a 6.4L owner thats going to donate their new truck as a guinea pig so to speak for Bio Diesel fuel testing.
Location: Dallas Texas | Registered: 25 November 2005Reply With QuoteEdit or Delete MessageReport This Post
cue
From what research I have done, it says that it will accept B5. So hopefully they have just been too lazy to test any higher amounts of Bio.
Cue
Please send that documentation my way Cool
cue
okay, after spending literally 2 hours of searching on the internet. I finally found the "documentation". Here is the link.
http://media.ford.com/products/presskit_display.cfm?veh...on_id=423&make_id=92
hopefully this works. I am very new to this forum.
Cue
cue
to save you some time it is the very last line on the page
Cue
Thanks!!! Cool And welcome to biodiesel.infopop.cc Smile
cue
So... what is everybody's opinion? Would you buy this truck and be comfortable running say B50. Also does anybody's vehicle have piezo-electric injectors. I thought that I have heard they are on the VW TDI. Any 2 cents, advice, comments would be appreciated. Thanks,
Cue
B50 in my opinion is too early to call but I'm enthusiastic.
I believe the MB C320/350 has had the Piezo's for a year or two now Smile
cue
I appreciate your input. Getting a little off topic, I made a test batch of biodiesel using the Dr. Pepper method. I washed it very thoroughly, and the Bio is now pretty clear. I took a small amount of Bio out and tried to ignite it, and it will not ignite. Should it? or did I just make some poor quality Bio
Cue
It will not ignite cold, the flash point of biodiesel is over 300F, warm it up to 300+f and try it and it would ignite just fine.
96 Passat Tdi Greasecar/B100
2000 Excursion 7.3L
Running on Homebrew B100
Location: New Hampshire | Registered: 05 March 2006Reply With QuoteEdit or Delete MessageReport This Post
Because of the seer number of home brewers as well as commerical faciltys out there that may or may not be making consistant ASTM quality fuel, I dont think there is a auto maker that will "approve" over 5 percent, maybe one has gotten brave.
2002 f250 7.3
83 300SD 280xxx miles
84 300SD 176xxx miles
B8200 Kubota
several other diesel engines
Registered: 03 November 2005Reply With QuoteEdit or Delete MessageReport This Post
Cue, to answer to question about why the BD wont ignite.
Biodiesel has to be pressurized to ignite the same as petro-diesel, same as jet-fuel.
A complete explanation can be found at http://utahbiodieselsupply.com/tutorialvideos.php
Scroll down to the 2nd to last video
Registered: 16 June 2008Reply With QuoteEdit or Delete MessageReport This Post
Most engines could "tolerate" a blend of horse urine and #2 diesel at 5%, so automakers "approving" 5% bio have engineered in their CYA safety margin so their warranty liabilities won't extend to a backyard brewer's diesel gone soapsucker.
But, many times neither will they cover damages from a bad tank of fuel pumped from Exxon, BP, or any of the other dinosoup retailers if they find out the fuel instigated a breakdown.
So I just shrug my shoulders and keep on brewing.
OON, North Carolina has mandated a B20 minimum for all diesels sold in the state intended for "official use".
Regards,
Keith
"The government is not best which secures mere life and property--there is a more valuable thing--manhood."
- Mark Twain's Notebook
2004 GMC Duramax 6.6 LLY now on B100 "Applejuice"
Location: Whiteville, NC | Registered: 11 March 2008Reply With QuoteEdit or Delete MessageReport This Post
is it my understanding that you are driving a duramax diesel powered by bio diesel? I want to buy one of those and seemed to find more negative than positive about bio and duramax
thanks dc
Registered: 28 December 2007Reply With QuoteEdit or Delete MessageReport This Post
I have already tanked up a 08 ford powerstroke with b100. ran to Baton Rouge and back for a biodiesel work shop at the LSU ag center . no problems. I am near New Orleans . I just can't believe this truck gets 11 miles to the gallon and it has less than 2 thousand miles on it. my old 96 f250 gets 20 miles to the gallon and it has 400,000 miles on it .that is running on b100.
ford needs to get it together
Location: new orleans area | Registered: 27 January 2006Reply With QuoteEdit or Delete MessageReport This Post
cajun,
was it just that one time? about how many miles was it? inquiring minds want to know! lol
Location: se wisconsin | Registered: 05 April 2007Reply With QuoteEdit or Delete MessageReport This Post
R U STILL RUNNING B100 CAJUN COWBOY??? IF SO, HOW'S IT GOING?
Location: Somewhere in the swamp... | Registered: 03 April 2008Reply With QuoteEdit or Delete MessageReport This Post
Are you still driving the '08 ford powerstroke with B100?
I have a '06 ford 250. Would like info. I am gathering info to build my own biodiesel process.
Can you suggest a system?
Registered: 15 August 2008Reply With QuoteEdit or Delete MessageReport This Post
The issue with the 08 is the DPF or Diesel particulate filter that is in the exhaust system, remove the DPF and your mileage will go up and you can run bio.
If it aint broke, dont fix it! But its ok to take it apart and see how it operates.
Registered: 08 August 2007Reply With QuoteEdit or Delete MessageReport This Post
