I have a /87 1.6 turbo and can experience the same effect,I just don't mash it. When this starts to happen it's usally the injection pump going out of calabration. The turbo on mine has a hose from the intake to the injection pump so it can sense the boost and alter the amount of fuel going in to go with the higher charge of air.
Just boosting the air charge probably won't gain a lot of power but it could clean up the smoke. It might be cheeper to rebuild the Injection pump than install a turbo/supercharger. I can do mine for 700 bucks up here and I would also suggest changing the injectors as well if they have a lot of miles on them, they should be under 50 bucks apeice and I've heard as low as $30 and they're not hard to change. The turbo uses a different injector as well. It's not a fundemental problem with the diesel but more of a wear problem. These engines were quite clean from the get go. 12 years off the grid and counting |
Thanks for the reply.
I can buy VW Injector Cores for about $10 each, so that is probably my next order of business. I'd like to build a "pop tester" in the next few weeks to help with testing and rebuilding my injectors. The pickup does well when running light, as long as I'm careful with the accelerator. But, it has serious problems with smoking when pulling a heavy load. |
Love to hear how that works out. What do you plan to use for the pump plunger? 12 years off the grid and counting |
There's a 6 mm fuel adjustment bolt on the distributor head end of the pump that may help with the black smoke. Loosen the locknut first (I think it's 13 mm), ccw = less fuel, cw = more fuel.
There are several design notes about making POP testers on the internet. http://biodiesel.infopop.cc/ev...11024582&r=860105721 http://www.peachparts.com/shop...wthread.php?t=224334 I was just planning on getting a "hand hydraulic pump" as shown in the Biodiesel.infopop.cc page. However, I'm wondering if it would be "more fun" to try to rebuild a small jack as done on the peachparts page. Reading the description by cornblatt, it sounds like there is an advantage of the jack based tester in that the jack cylinder acts like a reservoir to even out the pressure surges of hand pumping & release process. This may not be true of the hydraulic ram pumps. Whew... 3000 psi to work with!!!!!!!!! |
Your pump timing could be advanced. If your pump is not leaking don't consider rebuilding. I have 2 TDI Passats one with 402,000 and 307,000 miles original pumps, never off engine.
I never thought of using a port a power, cool one thing I would add a manual valve between the pump and the gauge so you can check leak down. The only tester I ever used was an old CAV unit that looked like it was made in the 50's it worked just fine and I rebuilt a lot of injectors with it. It's still in use today but not by me, unfortunetly 12 years off the grid and counting |
Thanks guys for the suggestions.
I haven't gotten the POP tester built yet. That is still on the agenda. However, I checked the ignition timing. According to the Bentley Manual... for the 81/82, they listed a "standard setting" and "Improved Performance" setting. Measuring movement of the cam in the IP, Standard Setting: .0327in to .0366in Improved Performance: .0366in to .0406in Mine was at .036in. I found the chart on the internet: Looking at the graph. Advancing the ignition increases the NOX emissions, but also significantly reduces everything else (CO, Hydrocarbons, and Fuel Consumption). I linked to this on a Diesel site, I assume it is meant for Diesels. So, I decided to set my timing slightly advanced, but within the "Improved Performance" range. Also, as suggested above. My IP had the throttle limiter bolt completely removed when I bought the pickup. I went ahead and put that back in a few weeks ago (borrowing the idle limiter), with only helping the issues a bit. According to Bentley, it should be set based on the no-load RPM's. But, I don't have a good tachometer for a Diesel. Anyway, I've now got it set so that the only smoke I can see is a tiny puff when I mash on the pedal... from standstill, enough to squeak the tires in 1st gear... then everything else is fine. And, it still seems to have some get-up-and-go empty. And, dropped the idle speed down a little bit too. I'll need to do a little more testing, (like getting out on the freeway), as well as hooking up my trailer again. The lathe looks small, but it is deceptively heavy. Enough that my Tractor didn't like carrying it at all. Note position of lathe, Left Rear in the air, and Right Front smashed to the rim. We'll see how I do for now. I'm still trying to decide if I wish to track down a 1.6 Turbo, 1.6 "Eco" Turbo, 1.9 Turbo, or a 2.0 Turbo to put in it. There is a SWEET 2.0L Turbo on E-Bay right now... Says it only has 7 Miles. I'm trying to figure out if it was a crash-test vehicle, or managed to get totaled pulling out of the Dealership Parking Lot. http://cgi.ebay.com/ebaymotors...fPartsQ5fAccessories My only problem is that the 2009 Jettas and Golfs get worse fuel mileage than the '80-something Rabbits and Caddies. I suppose for now, I should try to make the 1.6 work for me before trying any big changes. |
I've set my car up to deliever black smoke on diesel fuel.Its less or none on grease.
