Switching to biodiesel help
Hello all,
I have a 1981 Volkswagen diesel rabbit.
I am wanting to switch from petrol diesel to biodiesel.
I need to know what needs to be changed to run B100 biodiesel.
I know something about the fuel lines and the injection pump seal but I don't know which injection pump seal and I've been told that my car has steel fuel lines and what about the inlet hose does that also need to be changed to a biodiesel compatible fuel hose???
Can someone please tell me what I need to do or change to my car to run be 100 biodiesel without any issues???
can someone tell me where I can find clear biodiesel fuel line to put between the fuel filter and injection pump?
Thank you all so much,
~ Bunnyboy
1981 Volkswagen Rabbit LS Deluxe
Registered: November 18, 2013Reply With QuoteReport This Post
2013 sponsor
I'm in the same boat. Bought a really exceptional '82 Rabbit with the 1.6/5-speed. I'm concerned about the injection pump but have heard differing reports on how much of a risk exists in biodiesel getting to it.
We know that biodiesel will soften any rubber lines. I suggest changing any hoses, regardless of how short. On my F250, I always look for 30R9 SAE rated hose. They can handle high pressure and biodiesel. There are other materials on the market now as well.
Another thing I've considered is a boost pump near the tank to help push the biodiesel toward the engine. The viscosity of bio or any veg oil is typically heavier than diesel. I've been told the VW injection pump also serves as the fuel pump, pulling the fuel all the way from the tank, through the filter and into the engine. That sounds like a lot to ask out of a rotary vane pump. Therefore, I'm thinking of a low pressure diesel pump at the tank.
Hopefully, someone with VW diesel experience will chime in.
'82 VW Rabbit diesel 1.6l na
'83 GMC 6.2l Class C RV
'85 F-350, 6.9l flat bed
'85 E-350, 6.9l cube van
2 Mercedes 300SD's
Same situation for me. I have a 1.6NA that I'm rebuilding for a project car and I intend to run biodiesel in it.
Should I be concerned about the injector pump? Fuel hose is easy to replace, but I'd rather replace any seals on the pump before they melt.
Any idea how much would it cost for such conversion?
Registered: July 03, 2017Reply With QuoteReport This Post
Hi Jim Kart,
Welcome to the forum
I have been using biodiesel for about 16 years now.
All I have ever done is pour the biodiesel into the fuel tank and drive happily into the sunset.
The biodiesel may or may not attack your fuel lines and seals.
If it does bother some of the "rubber" in your car it does take time and you will probably get plenty of notice. Fuel lines typically months to years to develop a problem IF they are going to develop a problem.
I have never had a problem with seals in the IP but some people have reported problems, especially with PSA diesel engines (Peugeot, Citroen etc.)
Hey Tilly, thanks for sharing your experience and opinion about the topic.
Currently, I'm trying to work with my old Patrol to use biodiesel as its fuel. Hope I succeed.
By the way, read somewhere that when using biodiesel with an old diesel engine you have to change the fuel lines as it may be brittle. Is this really necessary?
Hi Jim Kart,
It is easy to tell if your fuel lines are brittle.
If they are brittle I would probably change them.
I agree and good point Tilly.
By the way. A pal of mine who owns a junk shop is offering a set of stainless steel fuel lining for a good price. Should I get it or there would be a down fall once biodiesel would flow in those lines.
I think that's overkill. not sure on the age of your vehicle but I would just pour in the bio. Ive never had a problem in the older vw's that I ran bio in. they were pre tdi units though
Thanks, and yes you may be correct about it being overkill.
So OK tried biodiesel. My first attempt the engine smoked like a chimney for some time then all cleared out. Performance wise, can't say any difference at all.
Hi Jim,
Where did you get your biodiesel
What percentage biodiesel
I can not recall smoking like a chimney on start-up being one of the problems people have attributed to biodiesel- that is certainly not my experience anyway.
However, it is a VW....
You mean it smoked immediately even as it was burning out the petrol diesel still in the fuel system on the first start-up.
Does your car normally smoke like a chimney on start-up
For peace of mind, I would replace the fuel lines. I got mine from 4wo|truck parts before. Make sure to use new lines made of Viton so that they are bio compatible. Don't forget also to check all the filters after switching over to biodiesel.
Registered: June 26, 2017Reply With QuoteReport This Post
Thanks, Tilly and Lexter. got my biodiesel from a pal of mine. Not really sure about the percentage. No it doesn't smoke before I added biodiesel.
