Biodiesel & SVO Home
Biodiesel & SVO Forums
Volkswagen pre TDI
HELP...bought a tired rabbit|
Have you changed all the filters? Fuel and air.
98 Jetta TDI with aluminim tank HotFox fuel pickup, HOH, FPHE, Coolant Heated VW Oil Cooler Filter,VegTherm, Injector Line Heaters, 6 port Pollak, and 3 port Pollak for Backflushing veg. filter 60,000 grease miles B100 - B20 Main Tank Fuel depending on outdoor temps. 83 Benz 240D 3 Gallon purge fuel tank, Heated Pickup Stock Tank, 12V pump, HOH, Coolant Heated Filter, 16 Plate FPHE, Injector Line Heaters, 2 Greasecar Valves, Looped on Veg., Return to tank diesel.and Injector overflow return to veg. tank |
member 2008 Sponsor |
perhaps, run some diesel purge thru it? Do you think it might be "fuel starvation" ? Have you change the air and fuel filters?
If none of that helps, maybe buy a Mercedes 300D. Let us know how it turns out. daw 1986 Mercedes 300SDL 2000 Dodge Cummins |
Check fuel filter,check the cable running to the IP (injector pump)to make sure it is pulling the IP full open when floored. If it is the head you will be losing antifreeze. If so you could try new head gasket 9 times out of ten these are cracked between the valves, you can get an off the shelf replacement with warrenty for 400.
Unfortunately I cannot offer any hopeful suggestions. I once owned a 1981 Rabbit diesel. It was a thoroughly miserable experience! When the engine was "good" it was my little Rolls Kin-ardly. That means it rolls down one hill and kin ardly get up the next. No joke, I was once passed on a steep hill in the Catskills by a loaded logging truck!!!! Then it jumped time on me and blew the engine. Long story longer, the replacement motor I got was even worse. the diagnosis was lack of compression in two of the four cylinders. You should get a compression test and make your decision accordingly.
The most informative test(s) is a compression test, and a leak-down test. They will tell you if the cylinders/rings are worn out or ok, as well as an indication of valve wear. VW diesels have tough valves, and yours may simply need adjusting. That would be nice.
Another useful test test is to check for combustion gas in the radiator (a good mechanic will have the test gizmo). This will detect a leaking headgasket, even before it blows. If those things all check out, then the problem is fuel, which means injector pump, or timing, or injectors. Other folks have already mentioned filters. Rabbits are famous for blowing head gaskets, especially when not properly overhauled (always buy new headbolts, and retorque per the shop manual, not per the generic instructions that came with the "no retorque" head gasket). I know of one (and only one) VW owner who didn't know the timing belt was supposed to be replaced every so often (90K miles?). He didn't even know his Rabbit HAD a timing belt, with over 300K miles on it. Some people are just lucky. I wish I was one of them. It also occurs to me that a vacuum gage on the IP inlet would help you diagnose the problem, even though your car hasn't been converted to SVO. It would rule out fuel starvation, or confirm it. Cheers, JohnO |
Could always check here:http://www.vwdieselparts.com/forum/viewforum.php?f=8
if you don't figure it out. GREAT site...VW gurus. -------------------------------------------------------------------------- `86 Volkswagen Jetta NA: 9 Gallon Marine Tank>Transmission Cooler Tank Heater>HOH>FPHE>Coolant Wrapped Veg Filter>2, 3 Port Hydraforce Valves>Temp. Probe>Line Heater Specialist Injector Line Heaters>Vegtherm on Return>"Crud Catcher">Loop Everyone Should Read "Ishmael" by Daniel Quinn |
Volkswagen pre TDI
