Sponsors    Home    Forums  Hop To Forum Categories  UK Biodiesel    Electrics + single phase
Hi guys,
i just wanted to make sure my circuit will allow me to run my processor before i assemble it.
ill have a 3kw heater and a 1500w pump with a single phase circuit and a couple of computers running in the background. etc
thanks in advance,
Mubs
Location: Preston, UK | Registered: 14 July 2008Reply With QuoteEdit or Delete MessageReport This Post
Assuming you are not trying to run the whole lot thru' one 13Amp fused plug top you should be OK-most domestic ring main circuits are fused/trip at 30 AMPS so can handle a total load of 7500 Watts-Are you sure your pump is 1500 watts?that is a very big single phase pump.
yeah its a tam120, i sort of have a big procesor (making 150l batches)
anyway so what your trying to say is that as long as i'm not trying to run everything from one plug socket then i should be fine right?
thanks.
Mubs
