Subzilla,
I've never done a comparison like that so I'm not sure if the bubbles are meth or soap or who knows. I do know however, that methanol is very easy to detect because of its odor. If your not sure if what you’re smelling is methanol, just step outside and take a couple of deep breaths then go back in and sniff a little. I say a little because it's rather unhealthy. The other choice might be to simply do a quantitative water test such as the one Troy has outlined. You can easily tell if there is any methanol that way. Chances are, if you have heat the sample fairly warm (160F or so) if there is methanol in there it will come out and you will smell it. You can just try to light a small sample but be careful. It's very difficult to see the flame of methanol burning. Of course I have to state the standard -Be careful bubbling the methanol out, it really does make a very flammable vapor. If you can collect the methanol vapors you'd be way ahead of the game. If you have an Appleseed processor then you’re just a simple condenser away. -mcguyver Water test 2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field. |
