How do ya'll think an intercooler would work as a condenser for a methanol still?
See this one http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...r4_PcY_BIN_Stores_IT I have just put togather a still using a 50 gallon HWH and a old car radiator as a condenser. It works but it's slow. Using the lower element 4500 watt 220 on 110 volts. I am also wondering would adding a 2 or 3 inch outlet to the condenser help? It's currently going out the top thru 3/4 black iron then 3/4 Braided vinyl hose. |
dont know about the intercooler idea, but you can run the white wire to one circut breaker and the black to a seprate breaker. both circuts on 240 volts only one and you have 120 volts.
wayne,
its possible but finding a switch that will carry the current isn't easy. you need a spdt switch. US power has 4 wires 2 hot, 1 neutral, 1 ground. NEVER run power on the ground wire. to wire the switch 1 hot to the element. the other to one side of the switch( not the common pin). wire the neutral wire to the other side of the switch. the common of the switch goes to the free side of the element or thermostat. this does require a 10/3 with ground wire. -dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Too fast, I don't think that's correct. With each wire to a seperate breaker, it'll only work when both breaker are on. Flip one off, you won't get 120 volts for long befor the other on trips.
This is because on a correctly wired 120 volt circuit the white wire goes to the common strip. Your way it's not. Dkenny, thanks, I'll keep my eyes open for one of those. Wayne Very funny Scottie, now beam down my clothes. |
An intercooler is basically the same thing as a radiator - it all comes down to heat transfer area. You can use a fan to improve the performance of the radiator that you are using now.
For more performance, I would suggest making a water cooled jobbie out of some 4 inch pvac, 1/2" flexible copper hose, and some miscellaneous fittings. I think Legal Eagle has plans for it - although i may be mistaken (concerning the "originator's" identity) - if i am, i most humbly apologize. |
Still wondering about this any ideas? |
the only place ive seen 4 wire 240 circuts are in mobile homes. you are correct the white wire is common. also ive never tried running a heating element on 1 leg of a 240 circut so i don't know if it would work or not but its worth a try.
btw, white = common red = power black = power copper or green = earth ground thanks for correcting me on that. |
also, depending on where you are:
green/yellow = earth ground |
JoeM runs his heat spear on both 120 and 240 using the same plug, diffrent boxes. You will have to get him to tell how it is wired.
2001 Dodge 3500 CTD running B100 Self appointed Minister Of Propaganda, Order Of The Semi Sealed Steel Drum Reactor |
