Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Methanol Recovery    Galvanized ???
Closed Topic Closed
Planning and gathering for my meth recovery reflux still.
Can I get away with a galvanized condenser shell? I realize my tank has to be something compatable with the KOH based glycerin but I'm wondering if I can use galvanized thin wall pipe on my condensor apparatus.
I want to use a piece of conduit for my stack and condenser. Its galvanized material and I'm wondering how bad the methanol vapor will react with it. Perhaps I should strip it with muratic acid and give the outside a coat of BBQ paint?
www.MurphysMachines.Com
Registered: 09 March 2006Edit or Delete MessageReport This Post
My concern is that steel (galvanized or otherwise) is many times worse than copper for heat transfer efficiency. You will need a bigger condensor, if the steel is doing the actual condensing and heat shedding.
Methanol will attack zinc eventually. I do not know the consequences of having disolved zink in the mix when you make you biodiesel.
Finest regards,
troy
Location: north america somewhere close to the midwest, or not | Registered: 29 May 2004Edit or Delete MessageReport This Post
Closed Topic Closed
