Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Methanol Recovery    Recovery of ... stuff
First methanol recovery is usually fine, but starts to get darker later. I have read that this may be water or glycerol distilling but wasn't sure. Does anyone know what this is and how to avoid it?
Location: VA | Registered: 23 March 2006Reply With QuoteEdit or Delete MessageReport This Post
Hey Renroh,
I think what you are referring to is after a while of distilling the glycerin will bubble up and come through the condenser tube. Try using less glycerin in the still or perhaps a less aggressive heat source. You can also add a reflux column to your still and this pretty much eliminates the problem.
mcguyver
2002 Excursion 4 x 4 with a 7.3 liter powerstroke and Several diesel trucks and equipment associated with the arborist field.
Location: Bonnieville, Kentucky | Registered: 20 June 2005Reply With QuoteEdit or Delete MessageReport This Post
Don't overlook that your catch bucket could be less than clean, too. I commonly get a slight brown ting to my recovered methanol, not because any glycerin is getting in there (I have a reflux column), but because I have a limited number of barrels and at some point WVO have been in every one of them.
I have recovered a few hundred gallons over the past few months. I have a clear tube on part of the recovery pipework so that is where I see the stuff. I always thought it was just glycerol and the recovery tank was too full, but had no common experience to confirm. Thanks for the confirmation.
Ross
