Sponsors    Home    Forums  Hop To Forum Categories  Methanol Recovery    Plans for Methanol Recovery
Does anyone have any plans for a Methanol Recovery setup? I'm going through about 100 gallon of glycerin a month and would really like to recover that methanol.
When I do a search it just turns out pictures but no plans. Thanks,
Buzz
Location: Louisville, KY | Registered: 16 July 2008Reply With QuoteEdit or Delete MessageReport This Post
utahbio.com
To my knowledge, this is the only set of plans out there.
http://www.b100wh.com
Then click on the Recovery Condenser link.
Also, http://www.make-biodiesel.org has a section on methanol recovery as well.
-Graydon
You could build an appleseed GL processor with a water cooled recovery setup (plumber's delight) and use it exclusively for glycerin methanol recovery. If you use NaOH, the glycerin will get very hard when its demethed and cooled so keep that in mind. Your plumbing will get jammed with glycerin goo.
That's the one I am going to build. Good job on the document Legal.
Bernie
1983 Mercedes 300SD
1995 Jetta GL
Location: between a rock and a hard place | Registered: 22 October 2007Reply With QuoteEdit or Delete MessageReport This Post
Thanks for the link back gents. I have since that page was made swapped out the pail for a 48 LT water heater 'cause I needed greater volume for demething.
The rest is the same though. I've bought a second ShurFlo pump to move water through the condensing tube. Way overkill I will admit, but at the same time the pump acts as a spare should my main one fail. Very reliable pumps those ShurFlo's; I now have 3 of them.
**B100 Heated Winter System
JGK
If you're a fabricator and can solder copper pipe and can tig weld or braze a fitting for a heating element to a stainless steel beer keg, there are great plans for stills and reflux condensers on the www.moonshine-still.com (I think). I found on another site, www.stilldrinkin.com, selling distillation setups that appear to have used these same plans.
Mine is a beer keg boiler with a copper reflux condenser I built from the plans at the 1st site. Works great. I can process about 10 gallons of glycerin a day and get alcohol that tests at least 96% purity.
-Jay
'98 Dodge CTD 12-valve
120 gal Crosslink HDPE cone bottom processor (yes, it's plastic and works like champ).
Location: Boise | Registered: 31 August 2005Reply With QuoteEdit or Delete MessageReport This Post
Here's our reflux still, it kicks ass and was easy to build. We get 98-99% purity every time, just have a thermostat on the top and we have both 220 and 110 hooked up- 220v to get it up to operating temps and then 110v to maintain less cycling on the thermostat.
http://www.biodieselpictures.com/viewtopic.php?t=614
