Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Methanol Recovery    what temp do you stop?
I start recovering methanol at about 145 to 160 degrees. Then after it quits turn the temp up to 170 then 180 the 190 maybe 192..... each time I turn it up I get more methanol....So at what point does water begin to substantualy pollute the methanol? If it is under 200?
Why does "some" methanol need more temp to be relesed?
Tell me again....Why do I have FOUR jobs??????
Registered: June 21, 2009Reply With QuoteReport This Post
2013 Sponsor
When distilling, the only temperature that counts is the temperature at the top of the condenser.
Tank temperature does not matter.
To answer your last question, the way I understand it is that methanol alone will boil at 149F but when mixed in solution with biodiesel or another liquid that temp rises. As you have less methanol that temp required for boiling will keep rising until it reaches the boiling temp of the other liquid.
If you use a reflux design you will get purer methanol.
and the reason the tank temp isnt as important is because when the methanol vapors rise and hit the condenser head, if the head isnt hot enough the methanol condeses and falls back down into the tank.
the tank can be 200+ degrees but as soon as the methanol makes its way up and hits that cold pipe it's all for nought
keep that condenser head well insulated
Location: northeast ohio | Registered: January 26, 2011Reply With QuoteReport This Post
Thanks for all your thoughts. I quess my real concern was the application of higher heat resulting in "less pure" methanol. It appears unless I start to boil water it's o.k.
2013 Sponsor
If you keep the temperature at the top of the condenser at 150F there will be no water.
do you have a reflux column? you should
measure and control this temp at 150F..just like Rich Da tech said..I have mine set at 152..why purity vs recovery time..152 is a little faster but slightly lower in purity..think 99.1 instead of 99.5..I use my recovered methanol for 27/3 testing.
I stop when the 'pot' temp reach 205F..why? equipment limits..if the equipment would handle 300F.. I would stop at 290F..reaching 290F vs 205F would take longer, but I would get more methanol out..there is a cost/time trade off here..I haven't looked into this since I have to stop at 205F
-dkenny
