Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  Methanol Recovery    Methanol recovery Acid Est.
Is there anyone recovering methanol for the leftover acid methanol solution. If not, what can be done with leftovers.
Registered: January 04, 2007Reply With QuoteReport This Post
DF
-you can put the acidic drainage into your byproduct from a previous base stage, it will be neutralized there and follow that with methanol recovery. Tom
What amount of acid/meth to base byproduct? Byproduct glycerin? Is there a way to track until neutral. Thanks David
to answer your question..
yes.. its what I've been doing since I built my still.
how much acid/base..doesn't matter not really trying to neutralize the base or the acid..
if you use a different indicator you can titration the methanol/glycerin mix to determine the ph
-dkenny
