Sponsors    Biodiesel & SVO Home    Biodiesel & SVO Forums  Hop To Forum Categories  Methanol Recovery    Methanol for sure???
I was at a friwends house recently when he was about finished processing and starting his menthaol recovery. When he first turned the heat off, temp was around 145 or so,the liquid started flowing out the bottom of the condenser at a good clip, it was so good a flow we both looked at each other an wondered. How do you know for sure it's methanol that's coming out??? He has a rig for a condenser and I wondered if he had a water leak from the 2" pvc going into the copper crimped tubing inside it. To make this short and to the question, how can you tell this is methanol??? How much does methanol weigh as opposed to water???
99 GMC Turbo Diesel
Location: Portsmouth, VA | Registered: 28 July 2006Reply With QuoteEdit or Delete MessageReport This Post
I think folks test with a hydrometer used for booze brewing.
2001 Dodge 3500 CTD running B100
Self appointed Minister Of Propaganda, Order Of The Semi Sealed Steel Drum Reactor
Pure methanol has a specific gravity of 0.7913 kg/l and weighs right at 6.6 pounds per gallon.
By comparison, water weighs 8.3 pounds per gallon. One liter of water weighs one kilogram.
HTH,
troy
With that said methanol weighs 791.3 grams/liter.
If your clever you can tell from the weight of your results what percentage of methanol you have. Assuming water is the only other component.
Bob
The Biofuel Clinic LLC.
Geneseo, NY
http://www.biofuelclinic.com/
Location: Western NY | Registered: 16 September 2005Reply With QuoteEdit or Delete MessageReport This Post
