Sponsors    Home    Forums  Hop To Forum Categories  Methanol Recovery    Plumber's Delight Condenser
Hello,
I am under the impression that the plans on the GL site for the Plumbers Delight condenser are for a appleseed size tank. Is this right?
Is there any reason why my 200gal air compressor reator wouldn't use the same size PD using the same specs as given on his website? Or does it need to be longer/wider because of my different reator size?
I've never set one up and really don't know much. Thanks for any help.
Registered: 25 February 2008Reply With QuoteEdit or Delete MessageReport This Post
Should work fine for any sized tank, provided you can control the heat input to the tank in the event you are overwhelming the condenser (gas is coming out the output instead of just liquid).
If you have a tank system that is capable of providing enough heat to overwhelm the PB as described, and want to be able to recover at the fastest rate you are capable of, you may want a larger condenser (longer, not bigger around), otherwise, just turn the heat down some at the beginning, then keep turning it up little by little as the flow out of the condenser slows down.
OK. So really you can't over size one. It could be undersized and the draw back would be gas and liquid in the methanol collections bin. Dies that seem right? I have had someone else tell me it is 1ft for every 1kw of heat. What is hard to determine in my situation is the heat KW going in exactly because I incorporate solar heat by a heat coil circulating the tank. My thoughts are to just over size the PD....what do you think?
200 gal tank, 4500watt element and solar coil. No thermostat.
I threw a comment on your other thread.
Thank you for your input. I wasn't sure where to post it to get the right exposure for this topic. I'll join you (and others) over there.
goldenisles
