you might look into getting a PID, SSR and a thermocouple. on Ebay you might be able to get all 3 for less than $70.
-dkenny '84 bluebird school bus, DD8.2L turbo 2006 Jeep Liberty CRD the Liberty is now running B100 99 dodge 2500 5.9l 24v..-mine |
Because of the flamable vapours be aware of the fire risk....
Most industrial controls intended for this sort of aplication are extremely expensive compared to standard stuff because the liability risks and extra steps needed to manufacture test and certify. Be very careful you don't create a situation where the parts you chose can cause an arc. |
member 2008 Sponsor |
Farmer, TroubledGus made some great points regarding the arc possibility, but I use a wet-bulb thermostat and place it about 6 feet away from my system to allow for the arc. Also remember that the bulb can be placed outside of the tank (like mine) and then adjust for the small temperature difference (about 8 deg for my system). Additionally most PID/SSR controllers will need an additional relay to account for the heater load. Have fun, Rich 1982 Chevy Chevette Diesel (retired) 1984 Chevy Chevette Diesel (retired) 2005 Mercedes E320 CDI |
Thanks guys for your quick feedback. That is a good point about the arc. Our setup is designed to be vapor free but you never know.
RichE320 what are you using for an aquastat? I think the high temp Honeywell I am looking at has the sensor bulb mounted close to the back of the control, but I could be wrong. Thanks, Farmer |
