As most of you know Methanol is the most costly portion of making Biodiesel and I know for a fact that after I react a batch there is always some condensed methanol on the underside of the lid of my processor when I remove it the next day.
I know nothing about how to re-use that methanol in another batch or for that matter extract any other methanol left the biodiesel / glycerol on the bottom. Is there a step by step process to explain how this works and how to make something to recover the meth? How much is actually recovered? I use 10.3 liters of methanol for my 47 liter batches. How much of that would I recover? Thanks in advance!! Clint My 4x4 Website: http://www.4wheeling.ca I also sell 55 gallon drums here: http://www.movebc.com 1989 Toyota Hilux Truck - 2.8 Liter Turbo Diesel 4 Cyl Engine! Right Hand Drive... Here is a Picture of it: http://4wheeling.ca/photos/showphoto.php?photo=26 |
You are using 22% methanol in your process.
Your process uses only about 16%; the excess methanol is used to guarantee a good conversion. In theory you should be able to recover some 25% of the initial methanol used, but in practice it's around 15 -20% (which is no chickenfeed!) You will need a still or set up your processor to be used as a still. Both methods are described here in the Methanol recovery forum. By far the most of the methanol will be in the Glycerine by-product and just a bit in the freshly processed BD. However, it makes sense to get the Methanol out of the BD as well, because it releases the soap left in the BD. I'm not going to tell you how to do things, there are very good posts here that describe the process better than I could. Good luck! |
The process uses about 12.5%. The rest is excess. |
Yes, with the exception of canola oil (11.3%), butter (13.6%) and coconut oil (16.3%), 12.5% is a good round number for the other oils.
I use Canola, so why would I not want to just react with say 12% rather then 22% and allow all that waste? Whats the theroy behind that?
The reaction converting oil into BD is an equilibrium reaction. The excess methanol is what ensures that the reaction proceeds in the correct direction. Otherwise, it can stall out and even reverse under certain conditions. If you like, you can read this article about 2 stage base/base. It explains it in a clear way, I hope. HTH. |
In addition to the equilibrium of the chemical reaction as described above by Andrew, there is a second reason to use excess methanol. The excess methanol serves as a solvent in which the catalyst resides at the end of the reaction. The catalyst is then removed with the methanol from the finished biodiesel. Some of the methanol with catalyst partitions into and is removed with the glycerol, the rest is removed with the wash water. In either case the excess methanol serves as the carrier of the catalyst and allows for the removal of the catalyst. If there were no excess methanol to keep the catalyst dissolved, then virtually all the catalyst would convert to soap during the biodiesel reaction. |
