I thought I'd share my new recovery setup where I can recover from the glycerol and Biodiesel at the same time.
1. After processing I shift the glycerol from the processor to the glycerol still (the smaller Hot Water Cylinder on the left) via the plumbing and using the site tube to turn the taps off once all glycerol is across. 2. Then I power on both Hot water Cylinders as stills. I use 3 aquarium air pumps which pump air down via copper tubing into the bottom of the cylinders creating a bubble mass not unlike bubble washing. This does two things, agitates the bio or glycerol and also aids in moving the vapour out the top of the stills and to the condenser outside the shed. 3. The condenser uses copper coil in a bucket with cold water coming in at the base and drains at the top so I can keep things as cool as possible. I wish to change to a radiator and fan and get away from using water entirely. With this design I am able to recover around 30% i.e. I use 33litres methanol to process 150litres wvo and recover at least 11litres which is at 97%+ purity with this pot still design. Once all the methanol is recovered from the bio after about 5 hours I transfer it to the washtank where I air wash it for 24hours and all done, passes 3/27 with instant clear results and water test for soap passes with no soaps….. Also the methanol to atmosphere is kept to a minimum ….. Bio Pics This message has been edited. Last edited by: HDJ80, HDJ80 Canberra |
I agree with Ryan -- lose the special effects. I couldn't look at it for more than a couple slides.
: EcoReality -- be the change! http://www.EcoReality.org : Veggie Van Gogh http://www.Bytesmiths.com/Van : Twelve diesels and counting; please stop me before I buy another diesel! (Anyone have a diesel chain saw?) |
