Sponsors    Home    Forums  Hop To Forum Categories  Methanol Recovery    How much total meth can be recovered?
Let's say I do a biodiesel batch and don't use any water at all. I seperate the glycerine byproduct and biodiesel and distil them seperately. What percentage of methanol can I expect to recover?
Thanks for the info.
walk softly, leave a small footprint and a big impression
Location: southwest | Registered: 22 January 2005Reply With QuoteEdit or Delete MessageReport This Post
I found the answer. It is possible to recover about half the methanol.
Thanks, mcguyver.
Around half is a bit approximate. It depends on how much methanol you start with, the feedstock and titration etc. With the oil must of us use, about 12% of the original oil volume will be consumed by the reaction. The excess methanol will be available for recovery.
For example, consider 100 litres of oil with 22 litres (22%) methanol used in the reaction.
The reaction will consume around 12%, or 12 litres. Therefore the quantity available for recovery is 10 litres.
Of course this only applies if you get full conversion. If your reaction fails 3/27 there will be more methanol available for recovery.
Registered: 21 June 2008Reply With QuoteEdit or Delete MessageReport This Post
sooooooooooo about half
95' Ford 7.3 Reg cab.
Location: Philly, Pa | Registered: 03 September 2009Reply With QuoteEdit or Delete MessageReport This Post
