Sponsors    Home    Forums  Hop To Forum Categories  Methanol Recovery    Reflux Column
I am interested in using a reflux column to increase the purity and quantity of methanol recovered during the methanol recovery stage. I have been looking into a few designs used for ethanol distillation in home-brewing and it seems that a similar design should work for more efficient methanol recovery. Thoughts?
Best,
The Dickinson Biodiesel Crew
(Our boss is Farmer)
Location: Dickinson College | Registered: 30 May 2008Reply With QuoteEdit or Delete MessageReport This Post
I built a 2" diameter copper reflux column and condenser from a set of ethanol condenser plans I found on the web. The reflux column is stuffed with copper pot scrubbers and is about 1 meter long.
The column works great!
I built one from plans I purchased off the internet as well at http://running_on_alcohol.tripod.com/id3.html.
Not the cheapest device out there but it returns 98-99% methanol. I was able to get the 3" copper tube from a friend and picked up the control valve from a Sullair air compressor heat exchanger I bought off of ebay. The result is nearly hands off operation for hours at time. I do find the need to adjust the heat input about 2x in every 30 gallon batch I distill.
Good luck.
Scott
2000 F250 7.3L Biodiesel
2006 Jetta TDI Biodiesel
4.5 kW Grid Interconnected Diesel Genset on WVO
Registered: 01 March 2008Reply With QuoteEdit or Delete MessageReport This Post
I found a nice set of instructions and calculators here:
http://homedistiller.org/refluxdesign.htm
I haven't tried it yet. Hopefully (if I'm lucky) will build one in a couple of months.
I second the advice about homedistiller.org. Great info there -- I built my 30" long reflux column from their designs out of 1.5" copper pipe using an offset Nixon-Stone head. Copper scrubbers for packing. All you need is in that site.
Location: Sierra foothills | Registered: 20 December 2000Reply With QuoteEdit or Delete MessageReport This Post
Thanks everyone. Sorry it took so long to reply. I checked out homedistiller.org and the design looked similar to what I came up with on my own after looking through some old chem text-books. I am currently working on building a 30" x 2" reflux column with copper scrubbers (I couldn't find stainless steel) packed inside. I'll let you know how it goes!
Sarah
Please do!
The biggest and most frustrating problem I'm finding is that all reflux columns are being designed for ethanol, so there's no real data about the purity of the methanol that can be achieved with a given setup. Any info on that matter will be greatly appreciated. Smile
My column is six feet of four inch id schedule 40 pipe, it's full of marbles, I have a PID controlling the head temp, I generally get 98-99% pure methanol out of it.
Thanks, that's good to know.
Have you tried using steel wool?
As per the site I mentioned earlier, you should get the same results with only a 2 feet high column...
Fabricator
You got a build up on that reflux column? I'd be interested in seeing how you made it.
Location: In the Pacific Somewhere | Registered: 25 January 2008Reply With QuoteEdit or Delete MessageReport This Post
That is why you see a flange at the two foot level, I tried steel wool, didnt work worth a crap, then I added four more feet of tube and tried steel wool again, still not worth a crap, so I filled the whole thing with marbles and it made 98.9% pure methanol the first try.
Fabricator
The top of the still is 1/4" steel, inside the still around the opening to the column there is an expanded metal cage which holds about 1/2 cubic foot of marbles, in these marbles is the thermocouple for my PID, I set it 155-158 degrees, so the PID causes the element to do whatever it has to do to keep these marbles at that temperature, above that is approximately another 50-75lbs of marbles in the tube, off the top of the tube there is 3/8 pipe into a condenser that has 20' of 3/8 copper tube inside 3" pipe, water circualtes in the 3" pipe and condenses the methanol, I can do 50 gallons at a time and it takes around 12 hours to get to a point where it is not worth trying to squeez any more out of the glycerine, a little blue pump circulates the glycerine pulling off the bottom and spraying on the top.
Hello Fabricator...I realize this thread is old, but perhaps you might get this. In the picture, it looks like there is a tube or something coming out the backside of the column about a foot or so from the bottom...what is it?
Registered: 17 July 2006Reply With QuoteEdit or Delete MessageReport This Post
From his description I would believe that the hose is for the water to cool the condensor.
