Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  General Biodiesel Discussion    diatomacious earth filter test - does not remove all the soot ! (Personal Album)
Closed Album Closed
by Tim c cook (created on )Gallery | Comments
This test was to try to remove soot from used engine oil using diotomacious earth pool filter medium. I assume it did remove some as the oil flow reduced considerably over the 1 hour test but the oil is still totally opaque and coal black. Ambiant air temp was mid 70,s F. The weather has turned cool but I will try another 5 gallon through this same filter when the temp gets back to the same mid 70's F.
The slideshow requires Flash Player 9.0.124 or higher.
Please click here to install it.
Closed Album Closed
