Ya water does a great job of killing weeds I guessing that on part biodiesel 10 parts water |
Over the weekend I had a small VO spill in my shop. I decided it was cleanup time. I grabbed a bunch of demethed glycerol and spread it on the concrete floor, scrubbed and flushed outside with water. Worked great.
About 30 minutes later I had thousands of roly polys crawling into my shop from the dirt drive outside. I guess the caustic in the glycerol was irritating them. I wonder how this would work as a barrier against termites. |
After I finished plowing about 20 acres this spring, I used the little bit of glycerin that I had to cover the shiney parts of my kverneland plow. To keep it from rusting. The same idea as using farm grease. It seems to be holding up well so far. It went on pretty slimey at first, but the liquid evaporated fast and formed a nice hard protective skin on the moldboards. We'll see how well it comes off the next time I use it.
Cheers Donnie |
Either/Both 1. Shoe polish 2. Flying insect bait Regards, Keith "The government is not best which secures mere life and property--there is a more valuable thing--manhood." - Mark Twain's Notebook 2004 GMC Duramax 6.6 LLY now on B100 "Applejuice" |
Technically not BD, but I use SVO instead of lighter fluid on the BBQ. I figure having peanut oil by products on my food is better than having whatever is in lighter fluid on it.
Works great to jumpstart a chimmney style coal lighter. |
Biodiesel is an amazing parts cleaner, I keep a 5 gallon bucket of the stuff handy for cleaning really grungy parts.
I even dipped carburetors in there, of course the soft rubber parts were gone, but those are replaced in the rebuild kits anyway. Everything comes out sparkling clean. Illegitimi Non Carborundum |
Biodiesel is a great solvent. I use the BD that accumulates in my 2 liter bottles from testing the BD with the shake em up test to clean out my oil collection filter. I think it works as good as acetone at no additional cost.
Add one more:
I own a small pressure washing company and have a hot water unit that uses diesel to fire the burner that heats the water. I did a job last week and ran 50/50 bio in it and it worked great. Now I can market that as eco friendly with some of the gov't contracts I do. |
I admit it's not biodiesel, but it's a very interesting use for vegetable oil.
YouTube video - Vegetable Oil PC Ken |
Glycerin Byproduct:
Release agent for concrete forms. That's what I used on the 2x12's for my new shed pad, and even the form board that was pinched between the pad and the stoop came out quick and easy. They end op a little sticky on your hands after you pull them off, but its construction: everything is dirty! I just used it demethed and straight up. I just had a 1 gal pitcher and I pour a little on the inside face of all the forms, and both sides of the above mentioned pitched form. |
It should work fine. I plan on using it in my dads garage furnace. Just remember the gel factor. I wouldn't go pooring it in the tank if it's outside. Try disconecting the line at the pump and run a new line to a 5 gallon bucket. |
I believe most furnaces need to be modified to burn biodiesel. For more info see Biodiesel for Heating. Ken |
You can check out this site for Kuma stoves. They are BD compatible. I'm picking up one this weekend. It's going into my gargage (10' ceiling) and planning on sucking the warm air (100*F plus) off of the ceiling and piping it into my living room with a 6" duct and in-line blower. I'm looking forward to a lot lower heating bill this winter!!!!! Jim... Jim... '03 Dodge Ram 2500, 5.9L Turbo B100 - 18,000+ miles 1,000+ gallons brewed |
No Ken, There is really nothing you need to do and nothing you need to convert. Just use it the same as any other fuel. ‘Conversion’ becomes necessary when you want to run your diesel engine on Straight Vegetable Oil (SVO) For some pre-1994 model vehicles it is said that you need to replace your rubber hoses with synthetic ones. |
Hi elmejor. What model oil furnace are you burning biodiesel in without modification? How long have you been running it on B100? Is it lighting off reliably? Would you like to move this discussion to the Biodiesel for Heating section? Ken |
...yes and now even fly a jumbo jet!!! air new zealand has done that!!! |
I make fire bricks from the Glycerin (mixed 50/50 with sawdust), it burns great!
It does a great job of waterproofing my old redwing boots! And when I walk through the house and forget to remove them it makes for great conversation between me and the wife.
If it aint broke, dont fix it! But its ok to take it apart and see how it operates. |
| Powered by Eve Community | Page 1 2 3 4 |
