Since people have raved over Biodiesel & Biodiesel Glycerin Based Soap, let's see if we can come up with all the different uses for Biodiesel & the by-product glycerin.
Biodiesel 1. Replacement for diesel fuel 2. Replacement for home heating fuel 3. Replacement for "Goo Off" 4. BBQ Cleaner 5. Rubber Eater 6. Tee-Kee Torch Fuel Glycerin 1. Engine Degreaser 2. Source of Methanol (Methanol Recovery) 3. Floor Cleaner 4. Make Soap from it 5. Compost 6. Emulsion Breaker OK, share the wealth...
Biodiesel
ant killer |
Demethed glycerin
Earwig killer I pulled a drip pan out from under my glycerin settling jug; I couldn't have squeezed another earwig into that shallow pool of glycerin if you paid me. One solid dead earwig/glycerin lump. Eeeeeeew! |
not sure about this one but i have been told people have used it as a 2 stroke oil.
How is it used as a Emulsion Breaker does anyone know. |
Biodiesel Glycerin can do wonders to break an emulsion. Here's the link to it: http://www.biodieselcommunity.org/breakingemulsions/ -Graydon
I heard biodiesel cures cancer...
www.MurphysMachines.Com The best Do-it-Yourself Construction Plans on the Internet! Waste Oil Heating - Biodiesel Systems |
member 2009 Sponsor b100supply.com |
Biodiesel does a number on bathtub soap scum.
Biodiesel
Paint stripper (it has 'gummed' the paint on my garage floor and blistered my car's paint when i didn't remove a filling spill once) Glycerine Used to clean anything that i get WVO all over (reactor, wash tank, floor, other equipment) |
I heard it will make hair grow back if you are bald... Don't need it yet, but I hope it's true just in case! |
It gives you a bigger... Oh never mind!! |
....wallet? At least in my case.
Illegitimi Non Carborundum |
It would make a good additive to a waterless hand cleaner; the kind they used to put petroleum distillates in, and put +/- limonene in now.
Biodiesel makes a lovely lubricant for use on a metal lathe. I never use K-1 any more. The smell is much more pleasant and it's FAR less toxic.
It's also not a bad substitute for WD-40, keeping in mind it may eat paint and/or plastic. WVO makes a pretty decent wood preservative, though I only have a couple of test pieces that are two years old. The next test I want to set up is to soak the wood with bio and then paint/roll it with wvo, to get better penetration. I also just rolled 50 2x10's prior to pouring a foundation. I'll let you know how wvo works as a mold release agent. Finest regards, troy |
I would bet that biodiesel would make a good parts washer fluid. I haven't tried it (I NEED all my BD I make!), but I've used regular diesel in my parts washer in the past since, at that time, it was far cheaper than the typical "parts cleaner".
B100 is great for cleaning/lube on wrenches and hand tools. Especially adjustable and channel-lock types. But be careful if they have dipped handles, it's usually a type of plastisol and the bio eats it quickly. I have also used B100 and glycerine as a lube and coolant on a metal lathe and drill press.
As an indirect use if you spill some b100 on the concrete garage floor and then walk in with wet shoes later it makes for a wild first "skating" lesson!!! |
Yeah; I have no plastic covers on any of my valve handles that are anywhere near the washing tank. That little bit of biodiesel mist builds up, the covers swell, and then they fall off. |
Just for a second I read "KY"...... .... there's a thought |
Olive oil works better for that. Illegitimi Non Carborundum |
Yea, but Popeye will kick your A$$ |
| Previous Topic | Next Topic | Powered by Eve For Enterprise | Page 1 2 3 4 |
