I tried to pre wash 10 gal of hi ffa oil 12.8 koh as soon as i added the water thru the methoxide port it emulsified and the pump would not pump i cleaned the lines and the pump worked ok the oil was a thicker consistency but pumped ok also it is murkier i drained the pump and the lines and it seems to be separating normally i think the water forced in by the pump with too much pressure does anybody have any other ideas as to why this happened please let me know
Location: Kennesaw Ga. | Registered: 11 September 2007Reply With QuoteEdit or Delete MessageReport This Post
You dont give enough information.
I used to get horrific emusions due to the impeller of my pump being so fast it was like a whisk.
But I only ever had an emulsion once when doing the 5% prewash; thats when i did an experiment and added 7%. So maybe you added too much water.
High titrating oil is always liable to be troublesome.
I would recommend a dry wash method - no emulsions, no waiting for days for drying, no waste of hot water, and greatly reduced hands-on time.
The 5% water prewash is normally done on biodiesel at the end of the reaction. If you want to wash your oil with water it's usually best to do it very gently.
I have some extra drums in Kennesaw that I need to get rid of.
If you want any of them let me know.
Ken
Location: Sellersville, PA | Registered: 17 May 2006Reply With QuoteEdit or Delete MessageReport This Post
I did it after the reaction and i think it was caused by the speed of the pump impeller i do have enough drums thanks for the offer
