Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Biodiesel  Hop To Forums  General Biodiesel Discussion    DSE Diesel Secret ??? Anyone know what they're selling?
Page 1 ... 12 13 14 15
Closed Topic Closed
DSE additive Material Safety Data Sheet
General
Synonyms: dimethylbenzene, xylol
Molecular formula: C6H4(CH3)2 This is a mixture of the three xylenes, m-xylene (CAS 108-38-3), o-xylene (CAS 95-47-6) and p-xylene (CAS 106-42-3), and often also contains ethyl bezene (CAS 100-41-4).
CAS No: 1330-20-7
EINECS No:
Physical data
Appearance: colourless liquid
Melting point: -48 C
Boiling point: 137 C
Vapour density: 3.7 (air = 1)
Vapour pressure: 5.1 mm Hg at 20 C
Density (g cm-3): 0.87
Flash point: 27 C (closed cup)
Explosion limits: 1.1 - 7%
Autoignition temperature:
Water solubility:
Stability
Stable. Highly flammable - incompatible with strong oxidizing agents.
Toxicology
Harmful if swallowed or inhaled. Eye, skin and respiratory irritant. May act as a narcotic. Typical TLV/TWA 100 ppm.
Toxicity data
(The meaning of any abbreviations which appear in this section is given here.)
ORL-RAT LD50 4300 mg kg-1
SCU-RAT LD50 1700 mg kg-1
Transport information
Personal protection
Safety glasses, good ventilation. Remove sources of ignition from the working area
General
Synonyms: albocarbon, mighty 150, mighty rd1, moth flakes, NCI-C52904, white tar, naphthalin, naphthene, camphor tar, tar camphor, moth balls
Molecular formula: C10H8
CAS No: 91-20-3
EC No: 202-049-5
Physical data
Appearance: white crystals
Melting point: 77 C
Boiling point: 218 C
Specific gravity: 1.14
Vapour pressure: 1 mm Hg at 20 C
Vapour density: 4.4 g/l
Flash point: 88 C
Explosion limits: 0.9 - 5.9%
Stability
Stable. Flammable - avoid sources of ignition. Incompatible with oxidising agents. Heat-sensitive. Sublimes slowly at room temperature.
Toxicology
May cause irritation. Toxic by inhalation or ingestion. TLV 10 ppm. Sensitizer. Possible carcinogen.
Toxicity data
ORL-CHD LDLO 100 mg kg-1
UNR-HMN LDLO 29 mg kg-1
ORL-MUS LD50 533 mg kg-1
IVN-MUS LD50 100 mg kg-1
ORL-RBT LD50 3000 mg kg-1
Irritation data
EYE-RBT 100 mg/mld
SKN-RBT 495 mg open mld
Risk phrases
(The meaning of any risk phrases which appear in this section is given here.)
R20 R21 R22 R36 R37 R38 R43 R45.
Personal protection
Safety glasses. Use efficient ventilation.
Location: Colorado | Registered: September 27, 2007Report This Post
Originally posted by gerbur:
I am very interested in the Diesel Secrets formula for quick diesel fuel alternative. Anyone out there have any experience with known issues of this cocktail method of making biodiesel? I've read the possible issues, but does anyone know someone who's had problems with this type, or similar, fuel?
It is very appealing due to it's quick nature and easy ability to make any batch size you need.
I have been using it for two years and several dodge trucks...check out www.turbodieselregister.com alternative fuels forum and you will hear all about DSE and how to make your own additive instead of buying from them. But yes their system works and costs .65 cents a gallon to make..
I don't know anything about this subject, but I recently saw a reference to DSE on the TDIClub forum, and the administrator has notified everyone that no new posts will be accepted on this subject without approval because of pattern of abusive practices. You can read more in TDIClub's archives. The following is part of the administrator's post:
Every few months we get a new round of posters who ask about Diesel Secret Energy. Most of these posters make one post asking about the product and never post again. They appear to be nothing but shills for the company.
With every new thread about DSE the common reaction from the membership is all negative so in the name of saving some bandwidth there are no threads allowed for this product or company. New members who post about DSE will be considered spammers and their accounts will be banned.
DSE has been discussed on TDIClub enough already so use the search to learn what the membership thinks of it.
Location: Hood River, OR | Registered: October 09, 2006Report This Post
That doesn't sound like too bad an idea. If there was any new development in the discussion, it would be different. But this topic has about 3 pages of useful content, and 12 pages of redundancy, (most of which I agree with by the way, but redundant none the less.)
Granted, this topic isn't all that busy anymore, but I am beginning to think (actually have for a while now) that closing it to further discussion would likely be in the interest of the folks footing the bill for the site. Any question that anyone could possibly have about DSE is answered somewhere in these 15 pages, probably more than once.
Tim
Location: Myerstown, pa | Registered: February 12, 2007Report This Post
How about we make a short "sticky" for the front page about DSE, and then close all future posting about it? Saves space...
1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1997 E300D Benz ... biodiesel.
Location: Cocoa Beach FL | Registered: September 12, 2005Report This Post
  Powered by Social Strata Page 1 ... 12 13 14 15
Closed Topic Closed
© Maui Green Energy 2000 - 2011
