quote: Originally posted by Reece123: Thats really neat..
How much oil did you manage to press from your 10lbs of seed?
Did not measure the oil myself. The seeds were not the best quality for oil. Just wanted to see how the press handled the seeds. Maybe 8 to 10 oz collected.
quote: Originally posted by taralec: That's some pressure in that press!-Do you heat the seed/press at all,to help the oil flow?Do the "canola dregs" go to cattle feed cake? Thanks
We do not heat canola seed. When it is cold we try to heat soybeans before pressing. The press cake is feed to the cows. It is very good feed. Temp in the press runs from 165 to 200 F.
Nice sound, sweet set-up.... it's so good to see folks like you closing the loops to get completely off terrorist oil. Every drop of Mid-east oil puts money in the pockets of people who want to destroy our culture. Good on ya Mate!!!
'89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends
| Location: North of 60° | Registered: 03 May 2005 |    |
member 2009 Sponsor
Cold temperature test of Camelina biodiesel made from locally grown feedstock. The oil was double-expeller pressed, filtered and degummed before transesterfication. A 750 ml sample was put into a cold oven. A type-K thermocouple was submerged in the sample and monitored on a strip chart recorder. Oil condition was checked after stabilizing at each temperature for 1 hour (min).
-6c slightly cloudy -8c cloudy "orange juice", possibly filter plugging -11c opaque, likely filter plugging, but still liquid -14c gelled solid
I was disappointed. I had been told that Camelina was superior to Canola at low temperatures. I had no filter plugging problems when driving my Land Rover at -20c on biodiesel I made from used Canola cooking oil (although I believe I was pushing my luck). Is there a difference between Canola oil as used for frying, vs expeller pressed and degummed Canola? Maybe. It's not unreasonable to believe that cooking oil has been "winterized" to remove the cloud-forming fractions that appear at refrigerator temperatures (so it has a nice appearance to the home consumer), but I'd surprised this would have been done to fryer oil.
The samples were provided by the Inland Empire Oilseed biodiesel plant in Odessa Washington. It's majority owned by the local grain growers union. I have high hopes they'll stay in business. for one thing, the farmers now have a steady supply of fuel at a predictable price. Too bad it won't work at our winter temperatures. Their plan is to blend it with enough diesel to make it work.
Nevertheless, this satisfies my long-time desire to power my truck with locally grown fuel. Until now I've only been able to use locally sourced used cooking oil, but it was grown somewhere else (we're not at war with Iowa, are we?)
Cheers, JohnO
| Location: Moses Lake, WA, USA | Registered: 15 August 2001 |    |
WOW, Now that is on helluva $hit spreader!! Those must be speed drills?!  How fast are you going drilling in the seed? Things have come along way since I used to help out on a ranch 25 years ago! Nice setup FF! Jon
| Location: Wellington County, Ontario Canada | Registered: 07 February 2008 |    |
