Home
Forums
General Biodiesel Discussion
Why 2007 & Newer ULSD Emission Vehicles Don't Like Biodiesel|
I'm trying to find out.
Kumar Plocher Yokayo Biofuels Fueled for Thought blog .........../ \.............. fueling / R \ evolution since 2001 '''''''''''''/____\''''''''''''''''''' Sustainable Biodiesel... |
Thanks Graydon, this is an excellent summary.
WOW, I LIKE IT... A SELF FILLING OIL SUMP!!!!!!!!!! Never having to worry about checking your oil at the filling station, and then having to dig around the back of the pickup for another quart of oil to add. In this case, always fill the sump to the low mark on the stick... or you could probably get away with filling it to a quart or so below the low mark. The oil really only needs to cover the oil pickup 100% of the time, and have a little extra to absorb heat and impurities. As mentioned, high oil can be far worse on an engine than low oil. Check your oil levels regularly, and drain if too high. Too bad you can't have a drain on the side of the sump like a transmission... just pop out the side drain and let the level drop back to "normal". I'm not sure how much oil you're talking about... but if you start at 20% below the low mark.. and then the high mark is an additional 20% higher, then by the time the sump is full, you'd have about 40 or 50% BD, and it would be time to change it out. CHECK YOUR OIL LEVELS!!!!!! Ok... Now to the root of the problem.
I'm still leaning towards redesigning the lubrication system to include a "dry sump", then using the fuel as lube. This would, however, limit a person to running only SVO or B100, and essentially NEVER run straight #2 Diesel. And, then the DPF Post Injection would be a mute point, and may even add to the cylinder lube (assuming there wasn't a coking issue). |
This article may come in handy...
How To Remove A DPF Filter (I also threw this in the first post under additional resources & will add more as I run across them or as people pose). Leave it to Diesel Power Magazine to show us how it can be done! Man I love that magazine! -Graydon
Now that's a cool idea!
But would that engine oil combust properly or would it just cause more problems in the DPF? Still a neat idea though. -Graydon
That's a great article! And it answers one question that keeps coming up: how often does the regen happen, or what triggers it?
But it also implies that this is not the ONLY signal that triggers a regen, probably happens at set intervals, too. Otherwise the easy fix would just be to knock out all the filter media in that can, and bolt it back on. The 2 back-pressure sensors would always show no plugging, and regen would never happen. |
I wonder if there's also a "default regen mode" in the systems too (kind of like water softeners that automatically cycle at a set interval whether they need it or not).
I'm betting each manufacturer may implement that slightly different, but yep, sounds like if you could disable those censors in the ECU you'd be set (oh yeah, and knock out the DPF media).
I would say this is on my wishlist, but I'm actively working to make it happen:
A federal regulation that all diesel technology from the OEM be tested and proven as 100% biodiesel compatible. AND, that for any that ISN'T, going back 5 years, the OEM's service center will either modify it to make it so for the consumer who requests it, free-of-charge, or offer the consumer a buy-back. At some point, I expect to turn this into a campaign, so y'all better be ready to spread the word!!! Kumar Plocher Yokayo Biofuels Fueled for Thought blog .........../ \.............. fueling / R \ evolution since 2001 '''''''''''''/____\''''''''''''''''''' Sustainable Biodiesel... |
I'm part of a forum dedicated to the Jeep Liberty CRD since I own two of them. These puppies are problematic to say the least - mostly because emissions controls were slapped onto them as a last minute afterthought. Part of the system routes nasty crap into the turbo, the EGR valves are notorious for failing every 20K miles and there are several sensors that need frequent cleaning or the engine simply won't run.
Many of the folks on the forum are diesel mechanics or serious hobbyists and they have figured out a fix for nearly every single problem. One of the guys even created a small circuit board that taps into the ECM and shuts off the EGR (it is NOT needed on the CRD) and then fools the engine into thinking it is on in order to prevent it from throwing a CEL. He has put together a circuit board kit and sold it to hundreds of forum members. It is truly remarkable what some of the people in these forums can come up with. Think of our own resident genius Graham Laming! Graham, Girl Mark and many others in here have advanced the science and art of brewing significantly in the past 5 years. I guarantee there will be a list of options for dealing with these obnoxious injection oversights within the next few years - probably even kits you can buy. At this point I would side with Legal Eagle: Gut the system & disable it. (I think it is actually a combination of things but as a manufacturing engineer I lean toward thinking these were oversights. Most of them are not familiar with BD so they just designed to what they knew.) |
And I'd add that "they designed to what they knew using AS LITTLE new parts as they could"
In otherwords, "Well, we've already got a fuel injector in the system, let's not complicate it, let's just squirt an extra blast of fuel into the piston, vaporize the fuel, & blow it out with an exhaust stroke! Whoala Problem solved! Man, aren't we smart? (as they all pat themselves on the back on the way to the boss man to tell him their plans)" It was easy to implement, only required a tweak to a software program (the ECU), the addition of two sensors (one fore & one aft of the DPF), and the DPF and catalyst tank. http://www.dieselpowermag.com/tech/general/0810dp_diese...delete/photo_01.html http://www.dieselpowermag.com/tech/general/0810dp_diese...delete/photo_03.html Problem solved! (or so they thought). Also, check out how fine of material is in that DPF! http://www.dieselpowermag.com/tech/general/0810dp_diese...delete/photo_04.html Or shall we call it the Fuel Mileage Robber!
This is what it looks like on a Dodge when you remove it...
http://www.dieselpowermag.com/tech/general/0810dp_diese...delete/photo_09.html Ah, beautiful, ain't it?
OMG! What a fiasco.
I forgot to add, I had breakfast this morning with two dodge mechanics, when I brought up this subject it got very interesting, these guys
HATE those Fing things, they have several trucks a week come in with plugged dpf's or malfunctioning dpf's or trucks not running right because of plugged dpf's, turbo diesels need huge volumes of air and they also need to get rid of huge volumes of air, so what do the geniuses do? Slap on a big old powerful blower up front then plug up the tail pipe with this garbage. They have actually had new truck owners screaming, eye bulging, spitting mad because their brand new truck gets 2mpg less than the old one because of these things, according to these guys they have service managers at lots of dealerships complaining up the ladder about these things, they knew of two new truck owners who are starting lemon law procedings. |
I still don't understand why the EPA had to go from such lax emission standards to the new Tier II Bin 5 Standards. It's a joke!
Don't ya love that DPF material? Fuel Mileage Power Robbing thing that it is! And the sad thing, all of the Big 3 did it too! (And Mercedes, and VW!) Is it me or does it seem like the EPA just has it out for diesels in the US? Suffice it to say, I bet the performance shops are doing REALLY WELL right now pulling those DPF's off of new trucks... This message has been edited. Last edited by: Graydon Blair,
A fool and their money are soon parted. It shouldn't take more than a grade 6 education to see why the big3 are tits up in the rhubarb. For half the money wasted on one of those instantly obsolete computerized wonderwaggons a person could buy an older more reliable diesel vehicle and have it fully restored to like new condition, AND converted to run on VO biofuel. The only reason people buy this new crap is because they've been brainwashed by the sophisticated marketing that preys on their stupidity. It should be obvious to anyone who still has at least half of their brain cells still firing that the throw-away society fostered by unrestrained marketing is the cause of this whole economic meltdown. If people can't see this, then they deserve what's gonna happen to them when it all comes crashing down around them. --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
If they are, they better not get caught! Stiff fines and penalties for removing and/or disabling emission control equipment in this country. You are not even supposed to do it your self, but ther are few who abide by this law. HTH Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
You could do the same with an old gas guzzler. But what you would not get is the power and mileage improvements that have come with the advancements in engine controls. Also, you would not get niceities like ABS, Traction control, On Star, or other creature comforts. Personally, I REALLY want to take a nice old big sedan and put a HO diesel in it! Blessings. Joe 1999 Chevy Suburban 6.5L TD 1987 Mercedes 300TD and 1986 Chevy Cube van 6.2L. WWW.RillaBioFuels.com WWW.RillaBioFuels.com |
I'm with you Kumar. the question I placed on Obama's site raises just that issue. It has been getting favorable responses as have yours. |
You might want to correct your thread title to show its 2007 and newer vehicles that have this DPF problem. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
| Powered by Eve Community | Page 1 2 3 4 5 ... 26 |
Home
Forums
