Is there a diffrence from lets say NAPA diesel brand filters to a BD filter? I am going put a filter on my pump B-4 it goes into my truck.
2007 Chevy Duramax
Bio Pro-150
Location: Fresno, Ca. | Registered: 25 February 2008Reply With QuoteEdit or Delete MessageReport This Post
Napa makes a ton of different filters, and I don't know what you mean by "BD" filter. I recommend that you take your purified, dry biodiesel and send it through a 10-micron or better (1-micron is ideal) filter. It helps to have a clear housing. It helps even more to have viton gaskets.
Kumar Plocher
Yokayo Biofuels
Fueled for Thought blog
Sustainable Biodiesel...
Location: Ukiah, CA USA | Registered: 19 September 2001Reply With QuoteEdit or Delete MessageReport This Post
I was thinking of going with a 2 or 1 micron. When I say BD filter I was talking about is there a difference between a bio diesel (BD)approved filter and a reg diesel filter? Thank you.
2007 Chevy Duramax
Bio Pro-150
G'day Lindsay;
I use a CAT 2 micron can as a final filter after the resin beds. I have the 49 model but if smaller with the same micron rating (2) is prefered the 50 model will do the job. You can see how I use it here.
Note on the chart the size comparison of what 2 microns is like. This can go a long way to saving the OME filter on your vehicle once the residual gunk gets cleaned out.
HTH
** 7 engines on B100
**Make Biodiesel.org
I use these: http://www.jmesales.com/item/122416/Cim-Tek-Biodiesel-B...er-E85-M85-B100.aspx
They are a little pricey but they are 1 micron biodiesel /e85 filters.
thanks
nitroman
Location: Oklahoma | Registered: 01 October 2005Reply With QuoteEdit or Delete MessageReport This Post
I have always used the non BG rated filters from JMEsales instead of the more expensive BD rated ones with no ill effect. I have cut apart used ones and found no soft rubber or mesh.
I use a NAPA hydrualic filter for my Fass fuel system, the filter I use is a 10 micron. Cummins recomends a 16 micron filter. It seems to me that useing a 1-micron filter could be and is overkill, but it won't hert anything thats for sure, Just for a propective note most water filters are 5 micron for water machines and ice makers and drinking foutains.
Ratski 96 Ram Dodge 2500 CTD, 3 Years, on bio-diesel.
Location: San Diego | Registered: 21 August 2005Reply With QuoteEdit or Delete MessageReport This Post
I know this is off topic but I think my duramax filter is a 4 micron? If that is the case I would want to keep it as fine as I could right?
2007 Chevy Duramax
Bio Pro-150
Not off topic, and yes you would. Before using resin purification I ran my BD through twin 2 micron CAT cans. I now only use one.
