You say you were running bio in your other trucks ? are they common rail ? There are so many variables that its hard to pin down , being certified is really not for sure , nobody is doing the complete test every batch , many processors , just like anything els , not every one is good at what they do , and every one makes mistakes . I would say that you made a mistake , there are some claiming to be running high % bio in newer trucks , but there are a lot of forums / posts stating of problems with high % bio , the manufacture says 5% for everyone but government , they are allowed 20% with the addition of extra water filtering . So that being said , its hard to say that you have some fault here , some with the supplier [ if you have any of that batch , you may be able to get them to take some blame ] . I have not tried to take apart any of those injectors , many newer electronic injects , do not completely disassemble , maybe there could be some way to clean . This is why I would not want to buy anything newer than a 12v - P pump truck .
Those 2 Ford powerstrokes are common rail but a much different setup with HEUI injectors, and the rail is lower pressure. The powerstroke injectors are very expensive if you need to replace them. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated.
| Location: N. Colorado | Registered: 31 August 2006 |    |
member 2009 Sponsor
quote: No warranty coverage and about $6,000 worth of damage. (labor, 6 injectors at $600 ea., system flush etc.)
This seems pricy for fuel injectors but not if they are used on a common rail system, because they are electronicaly controled injector,and yes they are exspensive. If you own a power stroke, you can to pay alot more for injectors because they have 8 injectors and they run about $300 ea,
Ratski 96 Ram Dodge 2500 CTD, 3 Years, on bio-diesel.
| Location: San Diego | Registered: 21 August 2005 |    |
This is a very common problem and wasn't caused by BD. They wont warranty it because Chrysler only approves 5% bio. Cummins says 20%bio is ok. IMO there were more than likely warning sings. They are usually hard start, white smoke on startup, poor fuel mileage, fuel in oil. If you are paying 6K for new injectors tell you mechanic to pound sand and find a reputable diesel performance shop in your area. New injectors from bosch are ~2300 and only ~3 hours to replace. You could also send your injectors in for repair. http://www.f1diesel.com and http://www.dynomitediesel.com/ both repair injectors at a fraction of the cost of new ones. If you want to run BD fix the pickup and sell it. You'll be better off with a 94-98.5 12 valve. The pump and injectors on them are stupid and will run just about anything.
I just bought a '05 Ram 2500 with 76,000 miles on it which I intend running B100 in. However, before I take delivery, it has to go into the shop to get a faulty injector replaced under warranty - and the P.O., AFIK, used DinoD full time. I don't think it's the Bio, just poor engineering - and the North American car manufacturers wonder why people are buying imports?
JohnF
| Location: Bourget, Canada | Registered: 28 December 2004 |    |
