Sponsors    Home    Forums  Hop To Forum Categories  Dodge Cummins    Dodge 2nd Gen 2-Tank Project
Hello Guys,
I am currently in the process of converting my 95 Dodge 2500 over to run on a 2-Tank system that is very similar to Sunwizard's.
I am taking pics as I go and I will post them very soon.
I just have a few quick questions.
I am trying to figure out the best way to splice into the steel fuel lines. Sun told me that the Fuel line is 3/8" and the return is 5/16".
Where can I get a 5/16" compression T Fitting locally??
Also, where should I T into the fuel lines. I am using manual valves mounted near my feet so I was thinking that would be a good place.
Thanks in advance Guys,
Zack Smith
http://www.libertyagrifuels.com
1995 Dodge Cummins W/ Custom 2-Tank Setup and 10 K miles on veg oil so far.
1984 300D-Daily Driver No Mods single tank and 20 K miles on veg.
Location: Knoxville,TN | Registered: 26 October 2007Reply With QuoteEdit or Delete MessageReport This Post
Also, will a coolant temp gauge from Autozone reliably detect temp of VO??
Have you tried a local hardware or plumbing store for the compression fitting? I found mine in a "Fleet Farm" in the plumbing section.
Yes, almost any coolant temp gauge should work with the proper plumbing. I prefer the getting a cheap Cyberdyne digital, or Glow Shift digital gauge. First, they start reading at 70 F, which is nice when it can be -40 outside where I live. Second, the place of installation is not limited to the length of the lead, which is the case with most mechanical temp gauges that are sold in auto part stores.
Registered: 24 January 2006Reply With QuoteEdit or Delete MessageReport This Post
KnoxBioBenz,
For anything hardware related I shop @ McMaster Carr online. They have most everything you could ever need and their delivery is very quick, at least for me. Good luck.
Location: Ladera Ranch, CA | Registered: 29 May 2006Reply With QuoteEdit or Delete MessageReport This Post
I purchased a digital temp gauge from the JCWhitney catalog for about $85 with the sender that I was thinking is a lot of money but it really does work good. I does not read until 70 degrees. But both of the ones I have work flawlessly and have for more than 3 years.
Robert
In Fort Lauderdale running a 1985 Gold Mercedes 300d custom aluminum tank (18) gallons looped return with return to diesel tank. HOH wraped filter FPHE. Greasecar valves.
Location: Ft Lauderdale, FL | Registered: 01 June 2002Reply With QuoteEdit or Delete MessageReport This Post
