Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Environment  Hop To Forums  General Environmental Discussion    TIki torch oil recipe?
Can I mix methanol that I do not make Bio out of it has been sitting in the back yard for years and use it as tiki torch fuel. I have a Citronella plant that is half alive in the front yard what if I warmed a little WVO the plant and mixed with some Methanol?
What ratio would work.
Bob
Robert
