Read-Only Topic|
Hello rlaxton
Hydrogenated oil makes very acceptable biodiesel. HOWEVER, the biodiesel may go solid at a fairly high temperature. Yes, you can dilute both high titration oil and hydrogenated oil. Saint Tilly |
What is bad oil?
I am collecting oil but not yet making bio. If its liquid running oil and not solid am I ok? So much info/so little sleep..I have recuring bio dreams - SAD I know! You only keep what you have by giving it away!!!! |
HI,
No, unfortunately it's more complicated than that. If it's liquid it can still be totally rotten. LIquid versus solid oils are the result of non-quality variables such as hydrogenation, animal fats, tropical fats, all of which makes acceptible biodiesel with worse cold flow properties than liquid oils , which are made from things like soy or canola or corn oil (at least in the USA). Anyway, the ways to test the oil are: sniff test : crude test. If it still smells like food and not offensive, it's probably still lightly-used titration, a test to see how degraded the oil is: http://www.biodieselcommunity.org/titratiingoil water content: oil also gets water in it from the frying process, or from rain if it's stored outside. Here are a pair of tests for looking for water in oil: http://www.biodieselcommunity.org/testingoilforwater for a crude test, and http://www.biodieselcommunity.org/quantitativewatertest/ for a better one once you have a scale to work with. Mark ************ Biodiesel Classes and Advanced Topics forums around the country: www.girlmark.com/tour Biodiesel Homebrew Guide: www.localb100.com/book.html Diary of a Mad Scientist blog http://girlmark.com/blog |
hi!
i've tried to make biodiesel using waste vegetable oil in a 500 mL batch, but it turned to solid and no glycerine settled at the bottom. it turns to light brown and white solid particles form the momemnt i add methanol and lye soln in it.this is the first time it happened, the previos batch i did had no problem, can anyone help me?thanks |
Read-Only Topic
