Read-Only Topic|
You mention maintaining the temperature. The water heater comes with insulation that can keep the oil at temperature for long enough to process in cold weather and days in warm weather. It has built in thermostats that can be wired to bring it up to temperature without overheating.
On the vent valve, you can remove it or wire it open. you don't need to close it. Make sure both your 30psi vent and the vent are plumbed to the outside. --------------------------------------- First, Make sure your Appleseed is wired like this: ----------------------------------- 1) Add the oil to the appleseed see here for ways 2) Turn on the heat and start the pump mixing. 3) Titrate your oil. instructions 4) make your methoxide see here 5) Unplug the Appleseed when the temperature reaches 130F 6) Add the methoxide slowly - It should take at least 15 minutes. 7) Continue to run the pump for an additional 1-2 hours. 8) Let settle overnight. 9) Drain the glycerine 10) pump the biodiesel to the wash tank. |
Thanks, Rick!
Read-Only Topic
