Biodiesel & SVO Home
Biodiesel & SVO Forums
"Getting Started" article
need help with acid oil
Read-Only Topic|
100g/L! Holy Sh!t! Are you sure your titration solution is correct?
If so, search for "Reducing FFA" in these forums. There are quite a few pre-treatments, oil washing, baking soda, sodium bicarbonate, and other stuff to lower the FFA initially, and if that still doesn't help, you are going to have to use the 2-Step Acid/Base method rather than the simpler 1-Step Base Method. The BEST method, though, is to get a source with better oil! And if you REALLY don't want to just chuck that other oil, mix in a little in each batch until its gone. I shoot for 5-7g/L titration (12-14 total for KOH). You can use a mix concentration formula to get an idea of the volumes to use of high and lower titrating oil to get a mix that is close to your goal; Tf = (V1*T1 + V2*T2) / (V1 + V2) where V = volume T = titration 1 is for oil 1 2 is for oil 2 and Tf is final titration of the mix. |
hi Ryan,
thanx for your help.i searched for reducing FFA and got some helpful information. i got acid oil from another source and the result is even more alarming. once i reduce the ffa i will let u know how it turns. naj. |
Read-Only Topic
