Sponsors    Home    Forums  Hop To Forum Categories  GMC 6.2 and 6.5    just purchased a 95 suburban with 6.5 diesel want to run bio
what is suggested as for modification in order to run bio fuels on my suburban with 200k miles.
as for as changing hoses injectors or?????
thank you
Location: sebastopol cal. | Registered: 21 November 2007Reply With QuoteEdit or Delete MessageReport This Post
Run bio for a couple of months at least to clean out your tank and lines then change your fuel filters. You will have to change your injector return lines to viton after a few thousand miles they will get soft & leak. Ditto for the fuel lines in the engine compartment get some sort of bd proof hose such as viton. Been on B100 for almost 4 years with my 95 burb good luck Dan
Location: coquitlam B.C, | Registered: 05 October 2005Reply With QuoteEdit or Delete MessageReport This Post
