Brian:
If your fuel is well made and passes the 3/27 test then you are good to go. If this is your first go around then I would take the time to drop the tank and give it a good cleaning (also good time to check the sender unit and steel parts for corrosion). If you do it now, then the clean out cycle will be much shorter. Typically on the 6.5, the engine looses response and feels doggy before it actually quits. Make it a point to use the water drain three or four times a week at first to check for drop out. Keep a spare (or three) filter on-board to be safe. You 96 should already have the Viton hoses so your good there. B20-B50 should give you no problems and if you find your fuel passes all the QC tests, then even B100 is good. Only issue may be your optical sensor in the IP. Anything less then crystal clear bio and they seem to act up. Happy motoring. Bill 91 Buick Roadmaster wagon, GM 6.2 diesel conversion 89 GMC 6.2 (now just and engine on the floor) 84 Mercedes 300D (now up for grabs) 94 Cadillac Fleetwood (next diesel victim) |
Bill,
Thanks for the quick response. I guess it's just first time jitters. I'm not so eager to drop the tank, The fuel I've made is all combined in one vessel and had it tested at a commercial production plant. The test results were excellent. I hear B20 is optimal for performance. Will do the water drain as you mentioned. Thanks. Brian 1996 K2500 4x4 6.5TD |
Weldshop
-I have a 1996 6.5 TD with 475,000 KM, it just loves B100 in the summertime. as far as being sluggish, if it's just dirty injectors, some B100 should fix that. you'll notice a much quieter engine after you change over and that puterid diesel smell will be gone! -and I agree with Bill, carry a spare filter or just change it out once a month for the first few months, there not that expenive. Tom " I don't know what I don't know until I know" 1994 GMC 6.5 Tubo 2005 Dodge ram 3500, 3 VW's 2000, 2002, 2005. |
