Well I finished 1 batch of oil yesterday and started another batch this morning. I sure am glad these centrifuge's came thru when they did. Just wish I had one a few years ago and I wouldn't have had to use so many filters. Just finished the second batch, 80+gallons in 2 days. I still think I'll go with a bigger pulley on the pump. I did check the CF temp while I was pulling off the good oil. I was reading 151 degrees.
I changed the pulley size on the pump to 6 1/2" with a 2" on the motor. Working better than ever. Pushing 80 to 100 psi with the bypass closed. While cleaning the CF i noticed the "o" ring was about to come apart. Tomorrow I'll cut and reglue it. Other than that, the only complaint is it's start to vibrate and make a lot of noise. I'm going to isolate it with nylon washers. There isn't any sideplay in the CF to the shaft.
I have a carbonator pump as I have seen with DieselCraft CF and wonder what size of particles in the oil stream affects the longevity of the pump.
Best regards |
