I get my valves here; just bought a few in fact.
3/4" brass ball valve for $4.73 and 1/2" valves for @$3.25. Michael |
At Habor Freight Tools again limited time 08-07
1/2 and 3/4 inch brass ball valve on sale - http://www.harborfreightusa.com/usa/tabviewer/startBrow...eview=&type=RET&simp Go to page 8 1994 F250 IDI 7.3 NA E4OD |
Harborfreight also has a good collection pump 12v it will pump 4 gal/min. $26.00
I just spoke with Walbro and explained that I was having a hard time finding a distributer of their FRB-5 pump. They sent me to VE Peterson Company who has lots of them in stock. The price for the FRB-5 is $94, but it goes down to $70 if you order 5 of them. They can be reached at 800-537-6212.
I will chip in for 2 of them, if anyone wants to go in on a purchase...
1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1997 E300D Benz using 50% diesel, 50% VO single tank |
put me down for two Omar
OK, new thread...go to it if you want to buy a Walbro FRB-5. I will figure out how many we need, and organize a group buy if you all want to.
http://biodiesel.infopop.cc/eve/forums?a=tpc&s=44760975...781013222#2781013222 1985 Mercedes 300D, sold, Heat exchanger and injector line heaters, all single tank. 1997 E300D Benz using 50% diesel, 50% VO single tank |
more info at this link http://biodiesel.infopop.cc/eve/forums/a/tpc/f/959605551/m/9731029162 We have been running road tests on this aluminum bodied, 3-port WVO/SVO 12-Volt Fuel Tank Selector Valve with Viton seal. It has 12-mm ports with 1/2 inch NPT threads--it even has a small red light that tells you when you have switched to WVO! We have run this valve in VW's, Mercedes', and a Ford F250 with a 6.9 with good results. Other details a few of you may want to know: Max operating pressure: 1 MPa (10 bar) = 145 psi anyway we have them in stock! $49 Omar www.omarsales.com |
Permatex high temp thread sealant
http://www.amazon.com/Permatex-Maximum-Temperature-Seal...id=1232821788&sr=1-3 or Permatex 80631 #14 Thread Sealant with Teflon, 1 oz. Tube http://www.amazon.com/Permatex-80631-Thread-Sealant-Tef...d=1232821234&sr=8-11 Sources for wvo thread sealant Omar www.omarsales.com |
