Sponsors    Home    Forums  Hop To Forum Categories  SVO Links    Cheaper parts
Hi folks,
looks like its an SVO discussion day for me...
I have been told several times that one can buy the same parts Greasel/others sell much cheaper at McMaster Carr, but I don't speak their language.
EX: the 6 port Pollak valve sold by greasel yeilds a dozen different parts. Yikes!!! Anyone know which is the correct peice?
What is the coolant coil inside the tank called?
Collection Pump: Greasel has a new $850 all-in-one collection pump. Anyone know how to make this for cheaper?
Any help would be great.
-Benjy
Location: VT | Registered: 21 December 2005Reply With QuoteEdit or Delete MessageReport This Post
here read thru this list of parts may help you ... sounds like you should just by a kit and start from there ???
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/1596.../681106491#681106491
Hi Omar,
many thanks for the thorough response. I am currently working on a list of parts and places. I think the big order goes out tomorrow.
I'm going to go with a 1000FH filter unit. Heat exchangers are the big question--I'm running a bus (8-10 mpg, hence a high flow rate) in a future cold environment (not at the moment). Only so much time to 'make my own.' I'm getting a Vegtherm mega, and have been recdommended 2!!! 'Tube-in-Shell" heat exchangers, at $195 each. One before filter, one before valves. That's still subject to change. I'm going to build a HotRod and wrap coolant lines around the filter. instead of an electric pad heater. I had not looked into FPHE, but they appear to take a while to arrive--I need them by Friday/Monday at latest.
Thoughts are welcomed from all.
Benjy
make sure your wvo valves can take the heat... use a temp gague before the ip.. good luck
A couple of good sources for replacement filters -
www.Filter1.com - sells Wix
www.adiesel.com - sells Baldwin, Racor
1994 F250 IDI 7.3 NA E4OD
use a sight glass that has meatal hose fittings... do not us the plastic screw in type they will crack (I ran one for about 5k before the plastic ends cracked in half)
http://store.summitracing.com/default.asp?Ntt=fuel+filt...target=egnsearch.asp
You can buy the sight glass here or Autozone has them for about $10.
do not over tighten the glass itself it can crack .. (I have done that too) however make sure it is not leaking air some times they vibrate loose just enought for a small leak so check for drips ... good luck Omar
www.omarsales.com
SPE-2228
part number
SPE-2228 Spectre Pro-Plumbing Fuel Filters
3/ 8 in. Hose Barb Inlet/ Outlet, Each
Today $9.95
Fuel pumps - These are the heavy duty type:
1. NAPA / Carter - P74017 - $66.00 at NAPA - 7% AAA discount + sales tAX .
2. Facet / Purolator PRO59SV Gold-flo - Pep Boys locally stocked , Advance Auto parts special order w- $69.00+sales tax
3. Walbro 6065 , 6013 - $80-100 www.autoperformanceengineering.
4. Aircraft Spruce ( www.aircraftspuce ) also has the Purolator - Facet Gold-flo pumps and light duty (ymmv) Facet Posi-Flo cube pumps in metal and plastic listed on their website.
5. Autozone - Master E8012S solenoid type universal elecric fuel pump 6-9 psi . About $ 32.
5"diameter x 119" long
1 micron prefilter bag
1 micron prefilter bags are ideal to filter waste vegetable oil. You can make several filter bags out of one tube ! Or you could make the mother of all wvo filters!!! We have a limited quanity of surplus Seamless Tube filter socks. Each one has a 5" hoop on one end... Anyway great price and like I said we have a limited quantity so order one or buy a box of 10 and stock up before they are gone!!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewIte...ame=STRK%3AMESE%3AIT
www.omarsales.com
http://cgi.ebay.com/ebaymotors/Gauge-Essential-For-Dies...mZ320018044407QQrdZ1
If you are running on (or thinking of running on) SVO/WVO with your diesel vehicle, then you need this product. Up for auction you will find one Fuel Temperature Gauge and necessary fittings, wires, and instructions to attach the gauge to your fuel line where the fuel enters the engine, with a back-lit, easy to read face.
hay....if you do not want to make your own take a look
Omar
www.omarsales.com
Smile
Replacement filter cartridges for Goldenrod Amber canister - Baldwin PF10 - www.adiesel.com , WIX 24042 water block , WIX 24043 - www.Filter1.com , Nationial Spencer NS20 (under farm filter) - www.jmesales.com .
hey all for a limited time I'm offering up this new power packed coolant heated filter housing for just $200.00 for the car version and $225.00 for the truck version to all forum members. PM me for info on how to purchase.
GreaseKing of Cali
www.greasekings.com
Another cheap filter source w/ Free Shipping on orders $75 or more - http://www.filterbarn.com/
Walbro fuel pump - FRB-5 ( the replacement for discontinued model # 6065- www.vegpower.com , http://www.autoperformanceengineering.com/html/fr_pumps.html
Harbor Freight Tools B&M - has brass ball valves on sale 1/2"-$4.95, 3/4"-$5.95 the red barrel pump -$12.99 thru 7-9-07
