Sponsors    Biodiesel and SVO Forums Home    Forums  Hop To Forum Categories  Straight Vegetable Oil (SVO) as fuel  Hop To Forums  SVO as a heating oil    200Kw+ output Diy waste oil burner
A you tube clip of a burner i built to heat my pool.
Do you have any pics of the burner? What did you do to modify it?
2001 f-350 ext cab 7.3. 04/10 DIY check valve system. 20 plate FPHE,Fass HPFP set at 70 PSI, TIH, Davco 322 filter head with 10 micron spin on filter,150 micron prefilter, Hydraforce purge valve, 60 liter poly tank with hotfox, ss braided hose to heads,, oil temp, pressure & fuel gauges.
Location: Nova Scotia. | Registered: July 26, 2008Reply With QuoteReport This Post
