Administrator |
We're building a new home and it will be off-grid for electric and water catchment. Any of you off-gridders out there care to share your experiences. I'm looking for info on what you would and would not do if building a new off-grid home.
The location is rural rainy Maui at about 1500 ft elevation. Our new home will be an 880sf bamboo house. We're looking at Uni-solar building integrated solar panels, but not 100% sure if that's the route for electricity since our site is not optimal sun, not bad necessarily, but not optimal. We also have a site on the property that looks good for wind, but we're not sure of the average wind speed so are getting an anemometer to find out. Of course we will have solar hot water, and we're looking at a 25,000 gallon water catchment system. It's a very rainy location, especially in winter (we think 100+ inches per year). Our back-up generator is a 7kw propane Onan, about 15 years old but runs great. Just couldn't afford a good diesel unfortunately, but we got lucky on the Onan at only $500 delivered and installed. Thanks for any input. Shaun 23 B100 vehicles 18 Bio-Beetle Rentals http://www.bio-beetle.com 4 Recycling trucks http://www.mauirecycles.com 1 1982 Mercedes 300TD |
My God! An off grid home in paradise! Do you have any streams on the property?
880 square foot sounds small, by continental standards. But, often it is easier to do solar/alternative energy in a small house.
This is an excellent resource for weather info: http://www.city-data.com/city/Hawaii.html I don't see Maui listed. According to the website, the number of cloudy days (in Honolulu) are pretty constant year-around which is good. http://www.city-data.com/city/Honolulu-Hawaii.html Contrast that to Eugene, Oregon where around January we start wondering if we'll ever see the sun again. http://www.city-data.com/city/Eugene-Oregon.html This website has a lot of excellent info about off grid houses, solar, wind, etc. Somewhat weighted towards wind power, but still a lot of good information. http://www.fieldlines.com/ So, a couple of questions that come up: 1 - What are you doing about living space heating/cooling? 2 - What are you doing about cooking? 3 - TV, Microwave, etc? There are a number of systems to choose from. However, if you are going to be off-grid, then I would encourage doing as much with 12V or 24V as possible. I.E. Run all of your lights off of 12V. At least I would only run my inverter when it was absolutely necessary. |
In that climate a large load will be electricity for refrigeration mostly to freeze and cool food, not including airconditioning. RV fridges offer some 12v options for running direct off solar charged batteries. Solar ammonia absorption cooling works too.
http://biodiesel.infopop.cc/ev...=418107232#418107232 --.- ..- . ... - .. --- -. / .- ..- - .... --- .-. .. - -.-- '89 Toyota 3.4L TDI + FPHE BD+ULSD+VO+JetB blends |
The reason I asked about streams is micro hydro with enough flow and head can make wind or solar completely unecessary.
Administrator |
We have a stream, but it only runs 4-5 months/year (Jan.-May), and we are looking into putting in a micro hydro.
(1) The only heating we will have is an old wood burning stove. Won't have an AC unit, and will use ceiling fans for any cooling needs. (2) All cooking and refrigeration will be propane, at least to start. (3) We did put together a comprehensive appliance worksheet that puts us at 100-120kw/month. It includes a couple of tv's that won't get much use and a microwave. Good advice on 12V/24V. Thanks for the reply's Shaun 23 B100 vehicles 18 Bio-Beetle Rentals http://www.bio-beetle.com 4 Recycling trucks http://www.mauirecycles.com 1 1982 Mercedes 300TD |
I disagree from my 22 years of living with and designing and selling solar power systems. Current inverters are 95% efficient. At 12 volts you will lose more than 5% in the wiring depending on the device, and each will need its own 10x larger wires run to it, instead of using standard 120v wiring and fixtures which are far cheaper and there are many more types of lights and fixtures to choose from. Many of the 120v lights put out more light per watt as well, more than beating the 5% loss of the inverter. There are a few things (some small pumps) that are more efficient at 12 volts, but not many. Propane Onans are great, especially if its an 1800rpm model. I have one and you can barely hear it when running. My main advice is to look at each device you use, usually there is a more efficient model, and it usually pays to buy the most efficient one even if it costs more upfront, since you then need less solar/wind. I don't like propane refrigs. They always put carbon monoxide in your house, which gives me a headache. Several of my neighbors with them had to completely repaint the inside of their house due to soot buildup on the walls after a few years, that can't be good for your lungs. Check out Sunfrost refrigs, they are great and will pay for themselves compared to propane costs. I have had one of them for 22 years and it still works flawlessly and only draws 40 watts compared to a typical frig which draws 300 watts. I have sold lots of them: http://www.sunfrost.com/ YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
Just thinking of alternative energy...
Has anybody done anything with geothermal energy in Hawaii? Oh, I see there is some... at least on an industrial scale. I'm not sure if it could also be translated into a micro scale. http://www.punageothermalventu...geothermal-in-hawaii |
Administrator |
Our Onan is an 1800rpm model, and you're right about how quiet they are. Thanks for the input on refrigerators, we have been set on getting a propane one, but we'll have to look at it closer to make sure we're making a well informed decision. Thanks for all the input. Shaun 23 B100 vehicles 18 Bio-Beetle Rentals http://www.bio-beetle.com 4 Recycling trucks http://www.mauirecycles.com 1 1982 Mercedes 300TD |
That would seem to really be the ticket, to me, if it could be worked out. Talk about any place in the world with an excess of geothermal energy! There and Yellowstone...and Iceland ... |
Administrator |
We decided to go with a brand name refrigerator, one with the lowest kwh consumption we could find. We figure the far lower cost of the refrigerator plus the extra cost of the solar panels/batteries will still be less than the $3500 cost of getting a Sunfrost to Maui ($3200 for the frig plus shipping), and it has more capacity to boot. Glad we received the advice about the propane frig's, we were deffinitely set on that option.
As for lighting, I'm looking at LED's as a way to significantly save on energy. Anyone have any input in using LED's to replace standard lighting in a house? From what I've found LED's are very expensive, especially the direct replacements for 60W incandescents $60 to $100 each Shaun 23 B100 vehicles 18 Bio-Beetle Rentals http://www.bio-beetle.com 4 Recycling trucks http://www.mauirecycles.com 1 1982 Mercedes 300TD |
I have not researched this myself, but I hear that if you already have hydro in place, and you have some elevation variation on your land, water is a very good way to store energy compared to all battery. Pump to the top of the land in the heat of the day when you have solar. Run water down hill to a lower tank in the afternoon/eve when you need power. It sounds like you will be half way there with the one large tank. Congrats on your project. Whatever you choose for your setup, please keep a good record. The rest of us might be coming to you for input soon. |
Oh,
Another thing for you to look up. Staber Washing Machines are one of the more efficient models out there. http://www.staber.com/ I must admit that capacity is somewhat small, but they certainly are worth exploring. I assume you're planning some kind of "line-drying". |
I've had a Staber for about 5 years. It has not been trouble-free, compared to our old Whirlpool top loader, and I blame the design. It does use less energy and less water, and does a good job cleaning clothes. The drum bearings already failed once (replaced under warranty, with an "improved" part, just before the warranty ran out), and the springs that hold the doors open broke, all close to the same time (classic fatigue failure), requiring taking the machine apart to replace them. It'll need it again in about 2 more years when they fatigue and break again. I've replaced the driven pulley once (warranty repair, the hub wore out - it's too small for the load in my opinion), and the motor bearings failed (they're not sealed, and got dripped on when the drum bearings failed). Luckily I'm handy with tools and can do the repairs myself (the motor bearings must be pressed out and new ones pressed in, saving nearly $400 over the motor replacement cost). I could have bought two Whirlpool or Bosch machines for the same price, but they would not fit the space we have in our 550 sq ft house.
The factory has been very responsive. I'll give them credit for good customer relations. The Staber has many fine features, but I expected 20 years of trouble-free service. As it is, I can expect a major repair every 4-5 years. Japan and China make highly efficient, small washing machines, much cheaper than the Staber. Cheers, JohnO |
For most frigs thats not true, but you can calculate whether its worth it. For example the most efficient Frigidaire (18 cu. ft) you can get draws 1100watt/hrs./day. Compared to the same size sunfrost which draws 480 wh/day. The extra panels/mounts/wiring/controls/batteries for the difference costs about $2000, depending on your supplier and sun hours per day. So your "break-even" point to buy the less efficient frig is $1500. But the batteries get consumed so in the long run the difference will be even more, add about $50-100/year to eventually replace the extra batteries needed (at current battery prices, and hope they don't double again as they did 2 years ago). This is an important decision since it will probably be your biggest power consumer.
LED's are still too expensive compared to CF's to justify the extra cost except in flashlights. Also the light spectrum isn't as good. If you get the LEDs with the warm spectrum (the only kind I would use since the blue spectrum ones bug my eyes quickly) they aren't more efficient than a good CF bulb that costs a tiny fraction of the price. $100 LED bulb 7.5w=260 lumens (=25w standard), (which is dim, directional, and hard to find higher brightness) while a $5 CF 9w=500 lumens (=40w standard) and you can get any other brightness and spectrum you like. Whatever you do, don't even consider "standard" lighting except in places you use less than 15 minutes a day. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
Administrator |
I'm really interested in looking at water storage power, but have not been able to find any info on a small scale system. Directly behind where we are building the house we have a 50-75 foot hill, and at the top of that hill there is a good half acre of flat land, so we have an excellent site if this is in fact a feasible energy solution. Potentially could put in water catchment up top also so wouldn't need to have a solar pump. Anyone know of such a system? We also have the stream 75 feet away/below the house that flows 4-5 months so looking to see if it's worth it to put in a micro hydro there. Conveniently the steam flows in the winter when it is cloudier.
Thanks for that, will look into it. Johno - thanks for the first hand experience.
The Sunfrost we were looking at (RF 19) consumes 770watt/hrs./day, so our savings is even greater. The one we bought uses 1070/watt/hrs./day and is just over 20 cubic feet. We paid $725 for it. In the long run we may have not made the correct decision, but we are going to be well over budget so we need to make some shorter term decisions that will help us keep our overall costs down.
Amazing how much they cost. We'll probably go with CF's, and deffinitely won't be using any incandescents. Shaun 23 B100 vehicles 18 Bio-Beetle Rentals http://www.bio-beetle.com 4 Recycling trucks http://www.mauirecycles.com 1 1982 Mercedes 300TD |
Conventional frigs fake their cu. ft. numbers in typical US style. A 20 of most conventional brands is close to the 16 cu.ft. Sunfrost in capacity. Consumer reports says that some that claim 25 are actually 16: Refrigerator capacity claims sometimes don’t add up You got a good price on yours, so you can afford to eventually replace the extra batteries needed several times. YVORMV - Your veg. oil results may vary, see www.burnveg.com/forum 95 Dodge Cummins 4x4 +87 300TD wagon Running on 2 tank WVO, 81 Mercedes 300D on V80/D20 blend Low fossil house- 100% solar/wind power, 90% solar heated. |
