Read-Only Topic|
Is the HEET bottle methanol (yellow bottle) and do you know the purity of your lye? Other than swirling it around, I don't know what other explanations.
The lye is the Roebic K-67 Granular Baterial Drain and Trap Cleaner. It was mixed with Heet from the yellow bottle. The lye just wouldnt dissolve very well.
I know it shouldnt work but I did mix it with the canola oil to see if I got anything. Its not looking good for now... |
I browsed the Roebic website and my assumption is the K-67 Granular Bacterial Drain and Trap Cleaner is NOT lye. What you're looking for is Heavy Duty Crystal Drain Opener (100% NAOH caustic soda). http://www.roebic.com/kitchen.htm Hope that solves the problem. I will be making my first batch this weekend...it's been 3 years in the making. |
Figures....I knew something wasnt right....I guess I shouldnt have mixed it with the oil....now I got some oil that i cant use....any suggestions for lye products?
Lowes should sell Roebic Heavy Duty Crystal Drain Opener (the proper caustic soda). I was going order some KOH from a supplier on eBay. You get a 2 lbs of lye in a resealable container (5 lb capacity) and 8 lbs of lye in four 2-lb bags. Since it's hygroscopic, I thought small quantities and something air-tight is a must. It's about $30 shipped and you can stack extra bags if you like. I think 30 lbs should last me awhile.
Keep this in mind for when you get a little further along. I have 50 pound bags of NaOH for $60 and 55 pound bags of KOH for $78 that I can sell you. I will be down in Auburn the week of January 14th to the 18th for school. I can also ship some smaller amounts if you need some before then.
-Jim www dot FryerPower dot com 1987 300DT (The sedan, not the wagon.) Some modifications to the fuel system. 1995 S350D Unmodified fuel system. I plead the 5th. |
Got the right stuff from the Lowes in the next town...given it a try here in a minute....(crossing fingers)
Jim D, thanks for the offer but for now I am just trying to make enough for about 2-5% mix just to help lubricate. When I am at a permanent location I might buy some of that for sure..... Thad |
If it is just Lube you need use 2% new canola oil.
Any idea where you are headed next? -Jim www dot FryerPower dot com 1987 300DT (The sedan, not the wagon.) Some modifications to the fuel system. 1995 S350D Unmodified fuel system. I plead the 5th. |
Read-Only Topic
