Sponsors    Home    Forums  Hop To Forum Categories  "Making a Small Batch" article    color of finished batch?
Read-Only Read-Only Topic
I've made two batches of BD using the soda bottle method, one with SVO and one with WVO. While I see separation in both, the WVO did not appreciably change in color and still has a caramel tint to it. Is this normal? Should I be expecting a more blonde product when processing dark WVO?
Location: Hudson Valley, NY | Registered: 11 April 2007Report This Post
BD from waste oil will be darker than that from new oil, but some lighter than the oil used was before being made into BD. This is normal. Generally, better conversion fuel can look a little lighter than poorly converted fuel from the same oil. But, don't use color as a quality test. Check out Jan Warnqvist's Conversion Test (3/27)
Andrew
Andrew
http://biodieselcommunity.org
03 Dodge 2500 B100 homebrew
79 Rabbit B100 homebrew
Location: Northern California | Registered: 27 February 2006Report This Post
Thanks, Andrew. I'll give this a go.
