Search on hot pan test to determine if you have too much water. It hasn't been compared to accurate tests like the karl fischer or sandy brae, but it detects somewhere around 500ppm = 0.05%, and that is the water limit most of us have been using.
bro frank,
the test results specially on diesel seem quite high. Is that within regulation standards there? Its .075% in several places I know. |
probably not. was told on a benz forum that the astm standard was .05% or 500 ppm. will be resampling this week.
In Christ bro frank |
has anyone thought about the dryers used in refrigeration, i dunno if there able to be used for svo or wvo but there used to remove moisture in refrigerants any idears? martin |
new results on oil and diesel.
Pump Diesel #2 was 0.0189% filtered WVOil was 0.0984% will try to get some bd from the same source as before along with a fresh set of results on the vo and #2. want to see if there's any consistence. willalso try to sample my 3 favorite diesel places the same day. Has any one else done any anylitical testing? In Christ bro frank |
