Sponsors    Home    Forums  Hop To Forum Categories  General SVO Discussion    3-Port Pollack? Used, even ...
After 4 years and 50K miles I've developed a leak along the seam between the solenoid and the valve portions of my Pollack 3 port. Causing a small vacuum leak.
Any one have one they're not using? Maybe moved up to a stouter valve? MikeGoodman59@aol.com
Mike Goodman
High Point, NC
1983 MB 300 SD (2 tank)
1982 VW Rabbit Truck
DC CF processing
Location: High Point, NC | Registered: 30 September 2005Reply With QuoteEdit or Delete MessageReport This Post
may want to look at this wvo valve
We have been running road tests on this aluminum bodied, 3-port WVO/SVO 12-volt fuel tank selector valve (also available in 24-volt) with easily-replaceable Viton seals. It has 12-mm ports with 1/2 inch NPT threads, a maximum operating temperature of 212° F, it is a bubble-tight valve (which means it is not going to leak like some of the other valves used for WVO) and it even has a small red light that tells you when you have switched to WVO! We have run this valve in VWs, Mercedes, and larger pickup trucks with good results.
For those who are interested, email me for a flowchart of the valves’ performance.
Other details you may want to know:
Max operating pressure: 1 MPa (10 bar) = 145 psi
Omar
www.omarsales.com
Are you having trouble finding one?
Merk
03 TDI WVO Converted. 12 gal marine tank in trunk w/copper heat excahnger no intank connections, coolant heated copper coiled fuel filter, HIH, two 3 port fuel valves
Location: Etna, NH | Registered: 19 January 2006Reply With QuoteEdit or Delete MessageReport This Post
